Building Netconf NED from only some yang files
nso20
I built a netconf NED with the yang files:
admin@ncs# show netconf-ned-builder project mycisco_ned 1.0 module status
NAME REVISION STATUS
Cisco-IOS-XE-features 2019-10-01 selected,downloaded
Cisco-IOS-XE-interface-common 2019-11-01 selected,downloaded
Cisco-IOS-XE-interfaces-oper 2019-11-01 selected,downloaded
Cisco-IOS-XE-native 2019-11-01 selected,downloaded
Cisco-IOS-XE-types 2019-11-01 selected,downloaded
Cisco-IOS-XE-yang-interfaces-cfg 2019-05-21 selected,downloaded
cisco-semver 2019-03-20 selected,downloaded
ietf-inet-types 2013-07-15 selected,downloaded
ietf-yang-types 2013-07-15 selected,downloaded
And could do partial-sync:
admin@ncs# devices partial-sync-from path [ /devices/device[name='mycsr']/config/native ]
sync-result {
device mycsr
result true
admin@ncs(config)# do show running-config devices device mycsr config
native ip domain name cisco.com
I would expect to set any configuration parameter inside native but have the below error:
admin@ncs(config)# devices device mycsr config native ip domain name mydomain.com
admin@ncs(config-config)# commit
Aborted: Network Element Driver: device mycsr: out of sync
nso20
rogaglia
When working with "partial-sync-from", you are expecting NSO and the device to be out-of-sync. Therefore, you should add some commits flags to set this behavior. Something like "commit no-overwrite" or "no-out-of-sync-check",  depending of the behavior you are looking for.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
