call get-modification on instance using restconf
Hello team,
how could I call "get-modications" on an instance using resconf api?
regards.
Nabsch
Hello Mamadou,
I give an example using l3vpn package
vpn l3vpn test-nestim
endpoint A
as-number 64512
ce device NETSIM-TEST-1
pe device NETSIM-TEST-0
admin@ncs# show running-config vpn l3vpn | display restconf
/restconf/data/l3vpn:vpn/l3vpn=test-nestim/endpoint=A/as-number 64512
/restconf/data/l3vpn:vpn/l3vpn=test-nestim/endpoint=A/ce/device NETSIM-TEST-1
/restconf/data/l3vpn:vpn/l3vpn=test-nestim/endpoint=A/pe/device NETSIM-TEST-0
You have to replace /data by /operations and add /get-modifcations at the end of the URL .  In order to use the operations , you should use the POST Method
curl -X POST -u admin:admin http://localhost:8080/restconf/operations/l3vpn:vpn/l3vpn=test-nestim/get-modifications
<output xmlns='http://com/example/l3vpn'>
<cli>
<local-node>
<data> devices {
device NETSIM-TEST-0 {
config {
vrf {
+ definition test-nestim {
+ rd 64512:1;
+ route-target {
+ export 64512:1;
+ import 64512:1;
device NETSIM-TEST-1 {
config {
router {
+ bgp 64512 {
+ redistribute {
+ connected {
</data>
</local-node>
</cli>
</output>
Best Regards,
Nabil
Nabsch
Hello Mamadou,
endpoint A
as-number 64512
<cli>
<local-node>
<data> devices {
config {
vrf {
+ rd 64512:1;
+ route-target {
+ export 64512:1;
+ import 64512:1;
config {
router {
+ bgp 64512 {
+ redistribute {
+ connected {
</data>
</local-node>
</cli>
</output>
Best Regards,
Nabil
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
