call get-modification on instance using restconf
Hello team,
how could I call "get-modications" on an instance using resconf api?
regards.
Nabsch
Hello Mamadou,
I give an example using l3vpn package
vpn l3vpn test-nestim
endpoint A
as-number 64512
ce device NETSIM-TEST-1
pe device NETSIM-TEST-0
admin@ncs# show running-config vpn l3vpn | display restconf
/restconf/data/l3vpn:vpn/l3vpn=test-nestim/endpoint=A/as-number 64512
/restconf/data/l3vpn:vpn/l3vpn=test-nestim/endpoint=A/ce/device NETSIM-TEST-1
/restconf/data/l3vpn:vpn/l3vpn=test-nestim/endpoint=A/pe/device NETSIM-TEST-0
You have to replace /data by /operations and add /get-modifcations at the end of the URL .  In order to use the operations , you should use the POST Method
curl -X POST -u admin:admin http://localhost:8080/restconf/operations/l3vpn:vpn/l3vpn=test-nestim/get-modifications
<output xmlns='http://com/example/l3vpn'>
<cli>
<local-node>
<data> devices {
device NETSIM-TEST-0 {
config {
vrf {
+ definition test-nestim {
+ rd 64512:1;
+ route-target {
+ export 64512:1;
+ import 64512:1;
device NETSIM-TEST-1 {
config {
router {
+ bgp 64512 {
+ redistribute {
+ connected {
</data>
</local-node>
</cli>
</output>
Best Regards,
Nabil
Nabsch
Hello Mamadou,
endpoint A
as-number 64512
<cli>
<local-node>
<data> devices {
config {
vrf {
+ rd 64512:1;
+ route-target {
+ export 64512:1;
+ import 64512:1;
config {
router {
+ bgp 64512 {
+ redistribute {
+ connected {
</data>
</local-node>
</cli>
</output>
Best Regards,
Nabil
