Change the Hostname using REST
Ivan Sanchez
I am working with my first programs in order to integrate NSO with REST, I already succeed making a REST Call using GET and DELETE but now I am trying to change the hostname of one of my devices through the POST method and I am getting some errors. These are my tests.
GET
http://IPADDRESS_NSO:8080/api/running/devices/device/ce1
Headers:
Authorization: Basic
Accept: application/vnd.yang.data+json
it works fine
DELETE
http://IPADDRESS_NSO/api/running/devices/device/ce0
Headers:
it works fine
POST
I have tried with several URLS
http://IPADDRESS_NSO/api/running/devices/device/ce1/config
Headers:
Body
    "tailf-ned-cisco-ios:hostname": "newhostname"
But I got this error in postman
    "errors": {
        "error": [
                "error-message": "unknown element: hostname in /ncs:devices/ncs:device[ncs:name='ce1']/ncs:config/ncs:hostname",
                "error-urlpath": "/api/running/devices/device/ce1/config",
                "error-tag": "malformed-message"
Someone can help me or point me out to some documentation. Thanks.
yfherzog
As the hostname might already be defined, you might need to use a PATCH rather than a POST method on your call.
I assume you refer here to the hostname command configured on the device (rather than the name of the device on the list of devices in NSO), so in this case, this is going to be located under the config container, and the exact command might depend on the specific device type.
If we use Cisco IOS-XR for example, then running the GET method you can see the structure of the running config which should point you towards the right structure on your PATCH/POST command.
For example:
YFHERZOG-M-W1ZZ:stacked-example yfherzog$ curl -u admin:admin -X GET http://localhost:8080/api/running/devices/device/xr-0/config
<config xmlns="http://tail-f.com/ns/ncs" xmlns:y="http://tail-f.com/ns/rest"  xmlns:ncs="http://tail-f.com/ns/ncs">
  <hostname xmlns="http://tail-f.com/ned/cisco-ios-xr">old-name</hostname>
In the case of the XR NED, we can see the hostname directly under the config container (/devices/device/config/hostname), but in your case it might be different, depending on the NED.
I will construct my PATCH command accordingly (I'll use XML for the payload, but you can use JSON as well):
YFHERZOG-M-W1ZZ:stacked-example yfherzog$ curl -i -u admin:admin http://localhost:8080/api/running/devices/device/xr-0/config -X PATCH -H "Content-Type: application/vnd.yang.data+xml" -d "<config><hostname>new-name</hostname></config>"
HTTP/1.1 204 No Content
Server:
Date: Sun, 13 Aug 2017 12:42:29 GMT
Last-Modified: Sun, 13 Aug 2017 12:42:29 GMT
Cache-Control: private, no-cache, must-revalidate, proxy-revalidate
Etag: 1502-628149-698901
Content-Length: 0
Content-Type: text/html
Pragma: no-cache
Subsequent GET, shows the new value:
YFHERZOG-M-W1ZZ:stacked-example yfherzog$ curl -u admin:admin -X GET http://localhost:8080/api/running/devices/device/xr-0/config/hostname
<hostname xmlns="http://tail-f.com/ned/cisco-ios-xr" xmlns:y="http://tail-f.com/ns/rest"  xmlns:cisco-ios-xr="http://tail-f.com/ned/cisco-ios-xr"  xmlns:ncs="http://tail-f.com/ns/ncs">new-name</hostname>
Hope that helps.
Yftach
yfherzog
For example:
Server:
Content-Length: 0
Pragma: no-cache
Hope that helps.
Yftach
For documentation, you can use the NSO Northbound APIs guide, which can be found under your installation directory.
Thanks a lot,, I changed to PATCH and change the body like this and it works!!!!
    <hostname xmlns="urn:ios">new hostname</hostname>
</config>
I have not seen the guide that you mentioned. Thanks.
I'm Glad it works!
Regarding the guide, you can find it together with the rest of the PDF guides, under the installation directory:
<nso-install-dir>/doc/pdf/nso_northbound-<nso-version>.pdf
