Check sync result unknown
romain.guilloux
Frequent Visitor
Frequent Visitor
Hi.
Some times after instantiate a service in NSO, I have got the following result from a check sync :
sync-result {
    device RNET-E14
    result unknown
Do you know what it mean ? When I have in sync or out of sync result I understand but not with that result.
sstrollo
The result unknown means that NSO doesn't have a record of a transaction id with that devices, and so it doesn't know if it is out of sync or not. Reasons for this can for example be: you have not yet done a sync-from, you have committed a change using the no-networking flag. You can look at wether a device has a transaction id recorded in NSO by show devices device <name> state if you do the last-transaction-id will tell you.
By the way, all possible return values from check-sync are documented in the file $NCS_DIR/src/ncs/yang/tailf-ncs-devices.yang, look for grouping check-sync-result.
Hope that helps!
/Sebastian
Jan Lindblad
It means the device doesn't support the check-sync operation. Instead of check-sync, you can try compare-config. Slower, but always available.
sstrollo
Hope that helps!
/Sebastian
This also happens when you add an SFP to a port - you will get the "unknown" state when doing a check-sync afterwards.
I encountered  this with NCS540 devices when a "proconfigure" port changes to a "real" port.
Martin
