Cisco NSO + ACI use cases
I saw that there is an APIC NED for Cisco NSO, I wanted to explore the use cases behind the integration of ACI fabric and Cisco NSO. Is there any ideas or anyone who has used Cisco NSO in combination with Cisco ACI ?
Thanks in advance,
KJ Rossavik
Thank you for your reply Rossavik.
Is it possible to use Cisco NSO Datacenter Core Function Pack (CFP) within a High Availability deployement mode of Cisco NSO ? Because all the documentation is talking about LSA.
Thanks in advance,
Yes, in the current version you can deploy each of the 3 LSA NSO nodes in HA configuration. In the upcoming release, you can use one NSO node, in HA configuration.
Cheers,
KJ.
Do you have an idea when the upcoming release will be published?
Thank you for your help.
