How to Python actionpoint to return a list of objects
lnunesdo
Hi team!
I have an actionpoint developed in Python that should return a list of strings.
Here's the piece from YANG:
module teste {
    namespace "http://example.com/teste";
    prefix teste;
    import ietf-inet-types { prefix inet; }
    import tailf-common { prefix tailf; }
    import tailf-ncs { prefix ncs; }
    augment /ncs:services {
        container action {
            tailf:action check {
                tailf:actionpoint teste-action;
                input {
                    leaf-list keypaths {
                        type string;
                output {
                    container result {
                        list service-types {
                            leaf name {
                                type string;
But I'm not able to find a way to return that list. The expected result is something like this:
<output xmlns='http://cisco.com'>
    <result>
        <service-types>
            <name>STAGING</name>
        </service-types>
        <service-types>
            <name>OSPF-OVERLAP</name>
        </service-types>
    </result>
</output>
In the action point Class, the output parameter is a Container.
Can anybody help me?
Thanks in advance!
I found the issue! In the YANG, the list service-types hadn't the key, so the output container had a keyless list which didn't permit including result names.
I fixed it and everything is working now!
Tks
snovello
you need something like
output.staging_parameter.create(‘STAGING”)
output.staging_parameter.create(‘OSPF-OVERLAP”)
just use the maagic API to populate the content of that output container.
Tks
