conditional "if" statement is not working as expected
amardkum
I have a python-and-template based service created using NSO5.3.
I am trying to make use of conditional statement - "if", in my config.xml.
<config-template xmlns="http://tail-f.com/ns/config/1.0">
  <devices xmlns="http://tail-f.com/ns/ncs">
    <device tags="nocreate">
      <name>{$device}</name>
      <config tags="merge">
        <feature xmlns="http://tail-f.com/ned/cisco-nx">
          <interface-vlan/>
        </feature>
        <vlan xmlns="http://tail-f.com/ned/cisco-nx">
          <vlan-list>
            <id>{/vlan-interfaces/api/settings/id}</id>
            <name>{$device}_api</name>  <!-- this will become "NSO1-ACCESS01_api" -->
          </vlan-list>
          <vlan-list>
            <id>{/vlan-interfaces/mgmt/settings/id}</id>
            <name>{$device-index}_MGMT</name>  <!-- this will become "[1|2]_MGMT" based on device-index value-->
          </vlan-list>
        </vlan>
        <interface xmlns="http://tail-f.com/ned/cisco-nx">
          <Ethernet>
            <!-- <?if {contains($device, 'ACCESS01')='true'}?> -->
            <!-- <? if contains($device, 'ACCESS01') ?> -->
            <!-- <? if {contains($device, 'ACCESS01')} ?> -->
<!-- <?if{$device-index = '1'}?> -->
            <?if{'1' = '1'}?>   <!-- even this condition is throwing 'Processing instruction is unexpected here' error-->
              <name>1/43</name>
            <?end?>
            <?if{$device-index = '2'}?>
              <name>1/22</name>
            <?end?>
            <channel-group>
              <id>{/port-channel-interfaces/core-access-peer/settings/id}</id>
              <mode>active</mode>
            </channel-group>
            <!-- <? if contains($device , 'ACCESS01')?>
              <description>{substring-before($device, '-ACCESS01')}-CORE01 Eth1/43</description>
            <? else ?>
              <description>{substring-before($device, '-ACCESS02')}-CORE01 Eth1/44</description>
            <? end ?> -->
          </Ethernet>
        </interface>
      </config>
    </device>
  </devices>
</config-template>
I tried multiple options, added as comment inside xml, but none of them worked.
Seeking some suggestion from the subject matter experts.
rslaski
In your template <name> looks like a key element of <Ethernet> list, and I am not quite sure whether 'if' statement can be used on list key elements. Have you tried moving your condition above the <Ethernet>, so it is applied to the whole list ?
rslaski
@rslaski, it works as expected when I used the conditional statement above <Ethernet>.
Thank you so much.
Could you please elaborate on how can we determine if the tag is a key or list key?
Error message didn't say much.
The general rule is that the XML has to be correct, no matter if the if-statement is true or not, so this also affects mandatory fields. Also, NSO doesn’t do any deep analysis of the code, so even if your cases are exhaustive, NSO doesn’t detect that.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
