ā06-04-2019 11:26 AM
In this configuration guide it is explained how smart licensing is enabled and how a smart licensing token is registered in IOS XR (ASR9k): https://www.cisco.com/c/en/us/td/docs/routers/asr9000/software/asr9k-r6-6/system-management/configuration/guide/b-system-management-cg-asr9000-66x/b-system-management-cg-asr9000-66x_chapter_010100.html
My customer needs to do the enabling and token registration from NSO, however it seems to me like it is not supported by the XR NED yet. The guide explains that when enabling smart licensing, I am supposed to enter administration EXEC mode and then in there, config mode. But it is not possible to go to config mode within administration EXEC mode in NSO.
In administration EXEC mode I can do the enable command in NSO, but the commit fails. Please see 1) below.
When trying to do the license smart register idtoken <token> command, I do not get the option to type the "register" keyword in NSO.
I use NSO version 4.7.4.1 and the IOS XR NED is the latest for NSO 4.7.4.1; cisco-iosxr-7.12.3.
Of course it is possible that it has been corrected in NSO 5.1 NED, but probably not???
What do you think? Have you experienced this as well? I guess we should have the NED updated by the BU?
1)
admin@ncs(config-device-ncs55a2)# conf admin@ncs(config-config)# cisco-ios-xr:admin admin@ncs(config-admin)# license ? Possible completions: smart Smart Licensing admin@ncs(config-admin)# license smart ? Possible completions: enable Enable Smart Licensing admin@ncs(config-admin)# license smart enable ? Possible completions: <cr> admin@ncs(config-admin)# license smart enable admin@ncs(config-admin)# commit dry-run outformat xml result-xml { local-node { data <devices xmlns="http://tail-f.com/ns/ncs"> <device> <name>ncs55a2</name> <config> <admin xmlns="http://tail-f.com/ned/cisco-ios-xr"> <license> <smart> <enable/> </smart> </license> </admin> </config> </device> </devices> } } admin@ncs(config-admin)# commit Aborted: External error in the NED implementation for device ncs55a2: command: sysadmin-vm:0_RP0(config)# license smart enable ---------------------------^ syntax error: unknown argument
Solved! Go to Solution.
ā06-04-2019 04:10 PM
ā06-07-2019 09:31 AM
So, the action is actually called any, so you are looking for something like
import ncs with ncs.maapi.single_read_trans('admin', 'python') as t: root = ncs.maagic.get_root(t) devs = root.devices.device any = devs['ios0'].live_status.ios_stats__exec.any inp = any.get_input() inp.args = ['license register sdfsdfsdf'] r = any.request(inp) print(r.result)
The last comment I made, well, it is a bit messy to do this in a service - because a service is assumed to be free of side-effects and license registration is a side-effect. You can still do it, but it is generally a bad idea - for instance it means that even doing a dry-run on the service would register the license, which is probably not what you want.
ā06-05-2019 12:33 AM
Yes, I see what you mean. So we cannot do the registration of tokens from NSO.
ā06-05-2019 05:57 AM
I am considering that maybe this could be done with RPC / MAAPI. Considering these ASR9k commands:
RP/0/RSP0/CPU0:router# admin RP/0/RSP0/CPU0:router(admin)#license smart register idtoken NmE1Yzg0OWMtYmJ4
What would they look like using Python high-level API / maapi? If possible?
I am reading the "Python API Overview" section in the documentation, however I have not yet figured out how to do it. I do not know how to get to the admin EXEC mode.
ā06-05-2019 07:11 AM
It is quite doable in NSO and this particular use-case is pretty common as well. There was a thread a few days ago that talked about how to call actions from Python, among other things, that might be some help: https://community.cisco.com/t5/nso-developer-hub-discussions/how-to-send-nso-commands-from-python-code/m-p/3863823
Your action in nso will be under /devices/device{X}/live-status, I would recommend that you explore that through the NSO CLI first to see what you want.
What makes this a little bit complicated is that this will also force you into some variant of the reactive fastmap pattern. Which is not a horrible thing, but does increase the complexity just a little bit.
ā06-06-2019 12:43 AM
Thank you for the guidance. I managed to do what I want from NSO cli:
admin@ncs(config-device-asr9001)# live-status cisco-ios-xr-stats:exec any admin "license smart deregister" result Wed Jun 5 19:14:26.523 CET license smart deregister: Success License command "license smart deregister " completed successfully. RP/0/RSP0/CPU0:ASR9K-SP-LAB-OPENNET# admin@ncs(config-device-asr9001)# live-status cisco-ios-xr-stats:exec any admin "license smart register idtoken .....ANjI4MDh8M0hFdytGNWhiRlhUT0o5U3F6UXByNzJ6YmJCeFpSWllGN....." result Wed Jun 5 19:17:19.806 CET license smart register: Registration process is in progress. Use the 'show license status' command to check the progress and result RP/0/RSP0/CPU0:ASR9K-SP-LAB-OPENNET# admin@ncs(config-device-asr9001)#
Now, trying to do that using the API's is a bit more difficult for me. I can succeed with a show command, like this:
In [14]: with ncs.maapi.single_read_trans('admin', 'python') as t: ...: root = ncs.maagic.get_root(t) ...: devs = root.devices.device ...: show = devs['asr9001'].live_status.__getitem__('ios-stats:exec').show ...: inp = show.get_input() ...: inp.args = ['isis topology summary'] ...: r = show.request(inp) ...: print(r.result) ...: Thu Jun 6 07:23:25.235 CET IS-IS BACKBONE IS Topology Summary IPv4 Unicast L1 L2 Reach UnReach Total/All Reach UnReach Total/All In Top In Top ------- ------- ------------- ------- ------- ------------- Router nodes: 0 0 0/0 2 0 2/2 Pseudo nodes: 0 0 0/0 0 0 0/0 Total nodes: 0 0 0/0 2 0 2/2 RP/0/RSP0/CPU0:ASR9K-SP-LAB-OPENNET#
But I am not yet sure how to do the "admin" followed by e.g. "license smart deregister" or "show license status". Tried this:
In [15]: with ncs.maapi.single_read_trans('admin', 'python') as t: ...: root = ncs.maagic.get_root(t) ...: devs = root.devices.device ...: asadmin = devs['asr9001'].live_status.__getitem__('ios-stats:exec').admin ...: show = devs['asr9001'].live_status.__getitem__('ios-stats:exec').show ...: inp = show.get_input() ...: inp.args = ['license status'] ...: a = admin.request() ...: r = show.request(inp) ...: print(r.result) ...: --------------------------------------------------------------------------- AttributeError Traceback (most recent call last) <ipython-input-15-6a051715b061> in <module> 2 root = ncs.maagic.get_root(t) 3 devs = root.devices.device ----> 4 asadmin = devs['asr9001'].live_status.__getitem__('ios-stats:exec').admin 5 show = devs['asr9001'].live_status.__getitem__('ios-stats:exec').show 6 inp = show.get_input() ~/ncs-4.7.4.1/src/ncs/pyapi/ncs/maagic.py in __getattr__(self, name) 470 return child 471 else: --> 472 super(Node, self).__getattribute__(name) 473 474 def __setattr__(self, name, value): AttributeError: 'Container' object has no attribute 'admin' In [16]:
I guess I need to watch the videos and read the API documentation..
Not sure what you mean with the comment "What makes this a little bit complicated is that this will also force you into some variant of the reactive fastmap pattern. Which is not a horrible thing, but does increase the complexity just a little bit."?
ā06-10-2019 11:55 AM
Thanks Viktor. That did the trick. Please find my results below. Please notice that:
- I had to use the 'admin' command before the actual license command. E.g. inp.args = ['admin','license smart deregister']
- Some strange errors when doing the show license status command. Please see in the bottom.
Deregister license:
In [8]: with ncs.maapi.single_read_trans('admin', 'python') as t: ...: root = ncs.maagic.get_root(t) ...: devs = root.devices.device ...: any = devs['asr9001'].live_status.ios_stats__exec.any ...: inp = any.get_input() ...: inp.args = ['admin','license smart deregister'] ...: r = any.request(inp) ...: print(r.result) ...: Mon Jun 10 19:40:38.465 CET license smart deregister: Success License command "license smart deregister " completed successfully. RP/0/RSP0/CPU0:ASR9K-SP-LAB-OPENNET#
Register license:
In [9]: with ncs.maapi.single_read_trans('admin', 'python') as t: ...: root = ncs.maagic.get_root(t) ...: devs = root.devices.device ...: any = devs['asr9001'].live_status.ios_stats__exec.any ...: inp = any.get_input() ...: inp.args = ['admin','license smart register idtoken ...mODctNjc3OWUxMWFmNDJmLTE1OTExNzUz%0ANjI4MDh8M0hFdytGNWhiRlhU ...: T0o5U3F6UXByNzJ6YmJC.......'] ...: r = any.request(inp) ...: print(r.result) ...: Mon Jun 10 19:44:16.769 CET license smart register: Registration process is in progress. Use the 'show license status' command to check the progress and result RP/0/RSP0/CPU0:ASR9K-SP-LAB-OPENNET#
Getting license status. Please see errors. Is there an error in the NED??
In [10]: with ncs.maapi.single_read_trans('admin', 'python') as t: ...: root = ncs.maagic.get_root(t) ...: devs = root.devices.device ...: any = devs['asr9001'].live_status.ios_stats__exec.any ...: inp = any.get_input() ...: inp.args = ['admin','show license status'] ...: r = any.request(inp) ...: print(r.result) ...: --------------------------------------------------------------------------- Error Traceback (most recent call last) <ipython-input-10-320ad354aa03> in <module> 5 inp = any.get_input() 6 inp.args = ['admin','show license status'] ----> 7 r = any.request(inp) 8 print(r.result) 9 ~/ncs-4.7.4.1/src/ncs/pyapi/ncs/maagic.py in request(self, params) 1535 tv = params._tagvalues() if params else [] 1536 cs = self._cs_node.ns() -> 1537 output = self._backend._request_action(tv, cs, self._path) 1538 outparams = ActionParams(self._cs_node, parent=None, output=True) 1539 outparams._from_tagvalues(output) ~/ncs-4.7.4.1/src/ncs/pyapi/ncs/maagic.py in _request_action(self, params, _ns, path) 137 138 def _request_action(self, params, _ns, path): --> 139 return self.request_action_th(params, path) 140 141 ~/ncs-4.7.4.1/src/ncs/pyapi/ncs/maapi.py in proxy(self2, *args, **kwargs) 1176 else: 1177 real = getattr(_tm.maapi, name) -> 1178 return real(self2.maapi.msock, self2.th, *args, **kwargs) 1179 setattr(Transaction, name, proxy) 1180 return getattr(self, name) Error: external error (19): External error in the NED implementation for device asr9001: Mon Jun 10 19:45:45.192 CET Smart Licensing is ENABLED Initial Registration: SUCCEEDED on Mon Jun 10 2019 19:44:26 CET Last Renewal Attempt: None Next Renewal Attempt: Sat Dec 07 2019 19:44:26 CET Registration Expires: Tue Jun 02 2020 10:53:30 CET License Authorization: Missing answer to a device question: +++ Mon Jun 10 19:45:45.192 CET Smart Licensing is ENABLED Initial Registration: SUCCEEDED on Mon Jun 10 2019 19:44:26 CET Last Renewal Attempt: None Next Renewal Attempt: Sat Dec 07 2019 19:44:26 CET Registration Expires: Tue Jun 02 2020 10:53:30 CET License Authorization: +++ Set auto-prompts ned-setting or add '| prompts <answer(s)>' Note: Single letter <answer> is sent without LF. Use 'ENTER' for LF only. Add '| noprompts' in order to ignore all prompts.
ā06-13-2019 01:37 PM
So, the problem you see there is that the NED tries to be smart, since some IOS commands are interactive. This can be used for instance for commands that prompt you for verification before doing something.
But, what happens here is that the NED things that the : signifies a prompt (it matches some regexp it uses to find prompts). As the text hints you can use the ned settings (set devices device X ned-settings) to configure the behaviour of prompting, that might be your best option in this case.
ā08-26-2024 11:20 AM
Thanks. This is really useful.
