03-22-2022 02:29 AM - edited 03-22-2022 02:30 AM
I have nso5.5 deployed in GCP and some openconfig-ned based ncs-netsim devices deployed for experimental purposes.
I have also 'cisco yangsuit' deployed (in the docker) in the same VM and also all the openconfig yang modules loaded in there.
yangsuit can ping the devices, upon 'ncs-netsim start' but can't connect to the devices using ssh over default port 10022 or 12022...... meaning, i can't run any RPCs.
I have made some configurations in devices using platform, system & network-instance modules.
Any help/guidance please?
03-22-2022 02:57 AM
03-22-2022 03:17 AM
Thank you snovello for the reply..
I have 3 openconfig-ned based netsim devices (127.0.0.32:12022, 127.0.0.33:12023 & 127.0.0.34:12024)... and, NSO can connect to the devices and configure them.
But the yangsuit tool can't open the socket on these devices saying 'Can't open the socket on 127.0.0.32:12022' and so... though, yangsuit can ping them on the devices on their IPs.
03-22-2022 03:49 AM
So I completely misread your question...
I have a suggestion here, the ssh command has really detailed logging when you turn on its verbose options and you can use it as a netconf client using the subsystem -s option
ssh -vvvp 12022 admin@127.0.0.3 -s netconf
and maybe that will give you a clue about what is failing.
The message about not being able to open a socket points to the fact that yangsuite is trying to reach a port where nothing is listening, that could be misconfiguration in yangsuite or misconfiguration of docker port translations for example.
