Create netsim device using openconfig-ned in NSO5.5
saumya003
Hello all,
I have openconfig-ned compiled and now, i am trying to create a network of netsim devices based on this openconfig-ned.
The devices are getting created and I can do "load merge" into NSO.
I can ping the devices but, I can't connect to them, means I can't create/commit any changes.
OpenConf-Dev-00 - 127.0.0.32 - 12022 - openconfig-ned-nc-1....openconfig-ned-nc-1.0
It's showing the error - Device OpenConf-Dev-00 does not advertise any known YANG modules.
If i change the port to anything in the range of 100xx or 120xx, then it gives error as 'connection refused'.
If i change the port to 830 (for netconf), then also connection refused.
I can ssh into the devices from install directory on port 12022 and it's replying back with netconf 'hello', but, the device is showing as default cisco/ietf yang modules/capabilities installed but none of the openconfig-yang modules.
Any help please??....
@Nabsch
Nabsch
Did you start your device ?   After creating your netsim , you need to start the netsim  then load device in NSO. Once Device is loaded in NSO , you need to perform a sync-from .  I think your issue is coming from the fact you  forgot  to perform a sync-from
Can you run those command ncs-netsim start ncs-netsim is-alive and provide the output ?
nabil@DESKTOP-8ECTID4:~/ncs-run-5.5.4$ ncs-netsim start
DEVICE TEST-IOS-XR-3.50 OK STARTED
DEVICE TEST-IOS-XR-3.51 OK STARTED
DEVICE TEST-IOS-XR-3.52 OK STARTED
DEVICE TEST-IOS-XR-3.00 OK STARTED
DEVICE TEST-IOS-XR-3.01 OK STARTED
DEVICE TEST-IOS-3.00 OK STARTED
DEVICE TEST-IOS-3.01 OK STARTED
DEVICE TEST-IOS-3.80 OK STARTED
DEVICE TEST-IOS-3.81 OK STARTED
nabil@DESKTOP-8ECTID4:~/ncs-run-5.5.4$ ncs-netsim is-alive
Best Regards,
Nabil
Nabsch
Best Regards,
Nabil
saumya003
Spot on.. thanks..
But, during device creations, it had not created .xml files which can be loaded.. so i created them manually.
