Default NED Loading Failure of cisco-iosxr-cli-3.5 in NSO 5.3
Fayyazii
Hello team,
I am using NSO 5.3 and default packages were L2VPN & cisco-ios-cli-3.8.
I tried to copy ios-xr-cli-3.5 from nso-5.3/packages/neds to /home/NSO/ncs-run/packages/ and then in admin mode i reloaded packages to see ios-xr addtional package too
I got error : *** ALARM package-load-failure: LOAD_PACKAGE[com.tailf.packages.ned.iosxr.IosxrNedCli]
and in admin@ncs# show packages package oper-status i get error of IOS-XR NEDs.
packages package L2VPN
oper-status up
packages package cisco-ios-cli-3.8
oper-status up
packages package cisco-iosxr-cli-3.0
oper-status program-code-error
oper-status error-info LOAD_PACKAGE[com.tailf.packages.ned.iosxr.IosxrNedCli]
packages package cisco-iosxr-cli-3.5
admin@ncs#
root@NSO:/home/NSO/ncs-run/packages# ls
L2VPN cisco-ios-cli-3.8 cisco-iosxr-cli-3.5
root@NSO:/home/NSO/ncs-run/packages# ncs_cli -C -u admin
admin connected from 127.0.0.1 using console on NSO
admin@ncs# packages reload force
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has completed successfully.
reload-result {
package L2VPN
result true
reload-result {
result true
reload-result {
result false
Does any one knows why its giving this failure/error and how i can fix them?
Nabsch
Hello ,
You need to check ncs-java-vm.log
