Enabling restconf on a CSR1000v
willian.este
Hello guys, i'm trying to enable restconf on a CSR1000v (03.16.03), but the service has not yet enabled.
I'm using the following docs but maybe i forgot something:
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/restapi/restapi/RESTAPIintro.html#97727
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01101.html
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/restapi/restapi/RESTAPIglobal.html
https://www.cisco.com/c/en/us/td/docs/routers/csr1000/software/configuration/b_CSR1000v_Configuration_Guide/b_CSR1000v_Configuration_Guide_chapter_01110.html
https://www.youtube.com/watch?v=uHvFZlpT6dw&feature=youtu.be&t=471
https://developer.cisco.com/docs/ios-xe/#!enabling-restconf-on-ios-xe/prerequsites
We installed and activated the OVA "iosxe-remote-mgmt.03.16.04a.S.155-3.S4a-ext.ova"
#show virtual-service list
Name                    Status             Package Name
csr_mgmt                Activated          iosxe-remote-mgmt.03.16.04a.S.155-3
and apply the following configuration commands:
netconf-yang
restconf
remote-management
  restful-api autosave 60 local-port 443
interface GigabitEthernet4
ip address 10.122.68.111 255.255.254.0
interface VirtualPortGroup0
ip unnumbered GigabitEthernet4
virtual-service csr_mgmt
vnic gateway VirtualPortGroup0
  guest ip address 10.122.68.112
activate
ip route 10.122.68.112 255.255.255.255 VirtualPortGroup0
onep
service set vty
But RESTAPI Feature and Guest interfaces are not enabled:
#sh virtual-service detail
Virtual service csr_mgmt detail
  State                 : Activated
  Owner                 : IOSd
  Package information
    Path                : bootflash:/iosxe-remote-mgmt.03.16.04a.S.155-3.S4a-ext.ova
    Application
      Installed version : 03.16.03
      Description       : CSR-MGMT
    Signing
      Key type          : Cisco development key
      Method            : SHA-1
    Licensing
      Name              : Not Available
      Version           : Not Available
  Detailed guest status
    Information not available
  Activated profile name: None
  Resource reservation
    Disk                : 756 MB
    Memory              : 512 MB
    CPU                 : 5% system CPU
  Attached devices
    Type              Name        Alias
    NIC               ieobc_1     ieobc
    NIC               dp_1_0      net2
    Disk              _rootfs
    Disk              /opt/var
    Disk              /opt/var/c
    Serial/shell                  serial0
    Serial/aux                    serial1
    Serial/Syslog                 serial2
    Serial/Trace                  serial3
    Watchdog          watchdog-2
  Network interfaces
    MAC address             Attached to interface
    54:0E:00:0B:0C:02       ieobc_1
    00:1E:7A:A1:19:BA       VirtualPortGroup0
  Guest interface
  Guest routes
  Resource admission (without profile) : passed
    Disk space    : 756MB
    Memory        : 512MB
    CPU           : 5% system CPU
    VCPUs         : Not specified
Like this:
Process               Status            Uptime           # of restarts
nginx                  UP         0Y 0W 0D  0: 1: 1        0
climgr                 UP         0Y 0W 0D  0: 1: 1        0
restful_api            UP         0Y 0W 0D  0: 1: 1        0
fcgicpa                UP         0Y 0W 0D  0: 0:13        0
pnscag                 UP         0Y 0W 0D  0: 0:13        0
pnscdme                UP         0Y 0W 0D  0: 0:12        0
Feature         Status                 Configuration
Restful API   Enabled, UP             port: 443
              (GET only)              auto-save-timer: 8 seconds
                                      socket: unix:/usr/local/nginx/csrapi-fcgi.sock;
PNSC          Enabled, UP             host: 172.25.223.233
                                      port:  8443
                                      socket: unix:/usr/local/cpa-fcgi.sock;
  Guest interface
  Interface: eth1
  ip address: 172.25.223.147/25
  Guest routes
  Address/Mask                         Next Hop                          Intf.
0.0.0.0/0                            172.25.223.137                    eth1
Could you help me please?
Regards.
WE
vpjaseem
Hi Willian,
The RESTCONF module is not present in all the releases of CSR1000v. Use Release Fuji to get RESTCONF feature. Here is the link for download. I have successfully tested this with csr1000v-universalk9.16.09.08.
Below configurations and Basic Authentication are required to get the RESTCONF working. Please note the user that is authenticating must have previlage 15.
restconf
ip http server
ip http authentication local
ip http secure-server
Example:
Abdul Jaseem
Hmm, however CCO account don't permit to get ISO image CSR1000 with support RESTCONF.
The interesting case: csr1000v-universalk9.16.09.08-vga hasn't interfaces after import OVA. No one!(
