NSO Developer Hub Discussions
Hi all, May anyone here know whether developer days will be organized in near future, or it is not decided yet or it is ended.Sorry if this information has already been made available and i missed it.Thanks and regards.
ekasnak by Community Member
  • 313 Views
  • 2 replies
  • 1 Helpful votes
Hi, all:I am using NSO-6.6 and I encouter NSO-6.6 logs the following warning:<WARN> 22-Jan-2026::14:24:55.214 MmapCSMountPoint Did-6-Worker-3: - failed to get children, path 107781231, mountId smf5.1-nc-1.0:smf5.1-nc-1.0 from MountPointDbThis does no...
sm000x by Level 5
  • 990 Views
  • 3 replies
NSO behavior running a python NSO action seems to be to create one python ExecuteAction instance that handles all callbacks from NSO. For example, this single instance is what handles two users invoking the action.Is there a way to get one python ins...
MikeG3 by Community Member
  • 1108 Views
  • 2 replies
I need to lock a sub-tree of the CDB.I developed an Action that reads and modifies data shared across all calls. Unfortunately, this action is usually invoked in bursts (around 10 calls within a fraction of a second), so multiple executions end up mo...
Fantolino by Level 1
  • 1150 Views
  • 3 replies
