Error: External error in the NED implementation for device mydevice: not implemented
Sagar Patil
Hello Experts,
Ubuntu 18.04.1 LTS
NSO 4.4.1
admin@ncs# show packages package package-version
           PACKAGE
NAME       VERSION
cisco-ios  3.0.0.1
admin@ncs#
admin@ncs# devices device mydevice live-status commands version
admin@ncs#
Kindly help me how to fix this issue. Or if there is anything missing.
Thank you.
yfherzog
Is that the NED version prepackaged with NSO?
As far as I'm aware, it is only intended to support the examples in the examples directory of your installation dir, and not much more than that.
I'd suggest you install the latest NED (should be 6.3.1) and retry.
Yftach
Dan.Sullivan
What kind of device are you trying this against?
-Dan
C7200
yfherzog
Yftach
Thank you! Yes, you are correct, I did install the latest one and it worked.
Best Regards
