Error observed during transition of configuration
gavaselv
I could observe error while pushing config via NSO. Seems like some environment variable issue or Device config is missing.
I have added new device(ASR-9k exr) in exising nso-4.7 setup. Downloaded Yang and installed drned properly as per the wiki.
https://wiki.cisco.com/display/XRNGSIT/Adding+a+netconf+device+in+NSO+and+building+Pioneer+NED+for+it
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# devices device ASR9K-gavas
admin@ncs(config-device-ASR9K-gavas)# ping
result PING 10.104.99.181 (10.104.99.181) 56(84) bytes of data.
64 bytes from 10.104.99.181: icmp_seq=1 ttl=239 time=234 ms
--- 10.104.99.181 ping statistics ---
1 packets transmitted, 1 received, 0% packet loss, time 0ms
rtt min/avg/max/mdev = 234.073/234.073/234.073/0.000 ms
admin@ncs(config-device-ASR9K-gavas)# sync-from
result true
admin@ncs(config-device-ASR9K-gavas)# drned-xmnr state record-state format xml state-name vrf-testcase11-bundle6
success Recorded states ['vrf-testcase11-bundle6']
admin@ncs(config-device-ASR9K-gavas)# drned-xmnr state list-states
success Saved device states: ['vrf-testcase11-bundle', 'vrf-testcase11-bundle2', 'vrf-testcase11-bundle5', 'vrf-testcase11-bundle6']
admin@ncs(config-device-ASR9K-gavas)# drned-xmnr transitions transition-to-state state-name vrf-testcase11-bundle6
failure PyTest not installed or DrNED running directory (/root/nso-4.7/nc/xmnr/ASR9K-gavas/test/drned-skeleton) not set up
Please help me in clearing this issue.
joepak
Can you provide the show packages package oper-status output?
Only thing I can think of relating to skeleton not being setup is the following:
ncs-make-package --service-skeleton python <package-name>
But I'm not entirely sure if it's related.
Or you are missing a python package called PyTest? Could you check the correlating ncs-java-vm/nso/devel.log files to see if it expands on the error?
mvolf
Most likely the problem is caused by what the error message says - you need to have pytest installed (can be installed by running pip install pytest in the system shell); and you need to set up the XMNR directories - run drned-xmnr setup setup-xmnr in the device mode. The latter prepares also the drned skeleton mentioned in the message, this has nothing to do with a package skeletons.
Let me know if it does not help.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
