Error with python script to fetch devices from NSO
jeyriku
Level 2
Level 2
Hi Team !
I am trying to create a script to fetch a list of devices recorded into NSO thanks to this code :
#!/usr/local/bin/python3
import requests
from pprint import pprint
nso_server = {
   "ip": "10.10.0.1",
   "username": "admin",
   "password": "admin",
   "port": "8080",
headers = {
      "Accept" : "application/yang-data+xml",
      "Content-Type" : "application/yang-data+xml",
module = "tailf-ncs:devices"
url = f"http://{nso_server['ip']}:{nso_server['port']}/restconf/data/{module}"
response = requests.get(url, headers=headers, auth=(nso_server['username'], nso_server['password']), verify=False).json()
devices = response['tailf-ncs:devices']['device']
# print out all the device name and IP
for device in devices:
    if 'test' not in device['name']:
        dev_name = device['name']
        url_sync = url+'/'+f"device={dev_name}"+'/'+'sync-from'
        sync = requests.post(url_sync, headers=headers, auth=(nso_server['username'], nso_server['password']), verify=False)
    print(f"device:{device['name']} -ip:{device['address']} -port:{device['port']} -sync result:{sync.text}")
As i am a python padawan, i can not even understand the errors returned when script execution fails :
Traceback (most recent call last):
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 700, in _update_chunk_length
    self.chunk_left = int(line, 16)
ValueError: invalid literal for int() with base 16: b''
During handling of the above exception, another exception occurred:
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 441, in _error_catcher
    yield
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 767, in read_chunked
    self._update_chunk_length()
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 704, in _update_chunk_length
    raise InvalidChunkLength(self, line)
urllib3.exceptions.InvalidChunkLength: InvalidChunkLength(got length b'', 0 bytes read)
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 760, in generate
    for chunk in self.raw.stream(chunk_size, decode_content=True):
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 575, in stream
    for line in self.read_chunked(amt, decode_content=decode_content):
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 796, in read_chunked
    self._original_response.close()
  File "/usr/local/Cellar/[email protected]/3.9.12/Frameworks/Python.framework/Versions/3.9/lib/python3.9/contextlib.py", line 137, in __exit__
    self.gen.throw(typ, value, traceback)
  File "/usr/local/lib/python3.9/site-packages/urllib3/response.py", line 458, in _error_catcher
    raise ProtocolError("Connection broken: %r" % e, e)
urllib3.exceptions.ProtocolError: ("Connection broken: InvalidChunkLength(got length b'', 0 bytes read)", InvalidChunkLength(got length b'', 0 bytes read))
  File "/Users/jeyriku/Documents/dev/ztp/Python_&_Rest/python_rest_v0.1.py", line 22, in <module>
  File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 75, in get
    return request('get', url, params=params, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/api.py", line 61, in request
    return session.request(method=method, url=url, **kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 529, in request
    resp = self.send(prep, **send_kwargs)
  File "/usr/local/lib/python3.9/site-packages/requests/sessions.py", line 687, in send
    r.content
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 838, in content
    self._content = b''.join(self.iter_content(CONTENT_CHUNK_SIZE)) or b''
  File "/usr/local/lib/python3.9/site-packages/requests/models.py", line 763, in generate
    raise ChunkedEncodingError(e)
requests.exceptions.ChunkedEncodingError: ("Connection broken: InvalidChunkLength(got length b'', 0 bytes read)", InvalidChunkLength(got length b'', 0 bytes read))
Some help would be appreciated !!!
Thanks in advance !
Kind Regards,
Jerems
Nabsch
Hello ,
I changed your script and it's working
import requests
nso_server = {
   "ip": "10.10.0.1",
   "port": "8080",
headers = {
      "Accept" : "application/yang-data+json",
      "Content-Type" : "application/yang-data+json"
module = "tailf-ncs:devices/"
path="tailf-ncs:devices/device?fields=name;address;port"
url = f"http://{nso_server['ip']}:{nso_server['port']}/restconf/data/{path}"
device_url=f"http://{nso_server['ip']}:{nso_server['port']}/restconf/data/{module}"
devices = response['tailf-ncs:device']
        url_sync = device_url+'/'+f"device={dev_name}"+'/'+'sync-from'
Here the output that i got
device:NETSIM0 -ip:127.0.0.1 -port:10031 -sync result:{
  "tailf-ncs:output": {
    "result": false,
    "info": "Failed to authenticate towards device NETSIM0: SSH host key mismatch"
device:TEST-IOS-XR-3.00 -ip:127.0.0.1 -port:10025 -sync result:{
    "result": true
device:TEST-IOS-XR-3.01 -ip:127.0.0.1 -port:10026 -sync result:{
    "result": true
5 Replies 5
jeyriku
Level 2
Level 2
It could be file permission related...let's check !
It's not permission related but urlib3 failure !
Let's Dig into that then !
A curl request does not lead to such issue.
Nabsch
Hello ,
import requests
nso_server = {
   "ip": "10.10.0.1",
   "port": "8080",
headers = {
    "result": false,
    "result": true
    "result": true
jeyriku
Level 2
Level 2
Hi @Nabsch,
I was missing the correct parameter typo:
?fields
in my restconf get method.
Moreover, The expected format was json instead of xml.
Why do i get an error when trying xml ?
Thank you so much,
Jerems
Nabsch
It's not working because when you try to retrieve your devices and you have more than one device. So NSO will try to send more than 1 device and you will have more than one root Element which is not Valid in XML.
I try on device it's fails but working on authgroup because i have only one.
nabil@DESKTOP-8ECTID4:~$  curl -i -u admin:admin "http://localhost:8080/restconf/data/tailf-ncs:devices/device?fields=name;address;port" -H "Accept :application/yang-data+xml"
HTTP/1.1 400 Bad Request
Date: Mon, 23 May 2022 22:54:42 GMT
Cache-Control: private, no-cache, must-revalidate, proxy-revalidate
Content-Length: 230
Content-Type: application/yang-data+xml
X-Cisco-NSO-Trace-ID: a4e9f8ab-d6a1-4ed7-927f-de7e11404c39
Pragma: no-cache
Content-Security-Policy: default-src 'self'; block-all-mixed-content; base-uri 'self'; frame-ancestors 'none';
Strict-Transport-Security: max-age=15552000; includeSubDomains
X-Content-Type-Options: nosniff
X-Frame-Options: DENY
X-XSS-Protection: 1; mode=block
<errors xmlns="urn:ietf:params:xml:ns:yang:ietf-restconf">
  <error>
    <error-type>application</error-type>
    <error-tag>invalid-value</error-tag>
    <error-message>too many instances: 6</error-message>
  </error>
</errors>
nabil@DESKTOP-8ECTID4:~$ curl -i -u admin:admin "http://localhost:8080/restconf/data/tailf-ncs:devices/authgroups/group" -H "Accept :application/yang-data+xml"
HTTP/1.1 200 OK
Date: Mon, 23 May 2022 22:50:04 GMT
Last-Modified: Fri, 20 May 2022 19:13:03 GMT
Etag: "1653-74064-499717"
Transfer-Encoding: chunked
X-Cisco-NSO-Trace-ID: 9727915c-d6a3-40ac-8696-4d1d5455d35e
Pragma: no-cache
<group xmlns="http://tail-f.com/ns/ncs"  xmlns:ncs="http://tail-f.com/ns/ncs">
  <name>default</name>
  <umap>
    <local-user>admin</local-user>
    <remote-name>admin</remote-name>
    <remote-password>$9$09ec/rAIrWPCWZZIv87YrZD8Q2oJa0RET3sX0JMadic=</remote-password>
  </umap>
  <umap>
    <local-user>oper</local-user>
    <remote-name>oper</remote-name>
    <remote-password>$9$afUGLCtUdztJBsxAnS6yULzCCqv10jzfe1f8OWw6pYc=</remote-password>
  </umap>
</group>
You have another option is to switch to Collection.
nabil@DESKTOP-8ECTID4:~$ curl -i -u admin:admin "http://localhost:8080/restconf/data/tailf-ncs:devices/device?fields=name;address;port"  -H "Accept : application/vnd.yang.collection+xml"
HTTP/1.1 200 OK
Date: Mon, 23 May 2022 22:56:22 GMT
Content-Type: application/vnd.yang.collection+xml
X-Cisco-NSO-Trace-ID: 3b8fb897-2894-4099-9ac6-4c0766e5224d
Pragma: no-cache
<collection xmlns="http://tail-f.com/ns/restconf/collection/1.0">
  <device xmlns="http://tail-f.com/ns/ncs"  xmlns:ncs="http://tail-f.com/ns/ncs">
    <name>TEST-IOS-XR-3.00</name>
    <address>127.0.0.1</address>
    <port>10025</port>
  </device>
    <name>TEST-IOS-XR-3.01</name>
    <port>10026</port>
  </device>
Here a link that might help you
