ESC snmp get threshold wrong target OID
neetimit
I am using ESC to deploy a CSR VNF on openstack and creating metric on ESC for CPU load threshold check to scale up and scale down. I have attached my ESC deployment xml.
ESC shows in mona.log file that it is hitting OID: UCD-SNMP-MIB::laLoad (.1.3.6.1.4.1.2021.10.1.3.1) to get the CPU avg load for 1min from CSR.
this is from the logs: Threshold Value from Agent :udp:98.6.63.71//161forrule:rule-VM_OVERLOADED-austx-lab-dev-esc-01-vnf-info-csrscal8__929824d8-f97a-4979-bba1-d2fb8ac741c0__0 for .1.3.6.1.4.1.2021.10.1.3.1= 0.0
I checked on Cisco MIB locator tool that this OID which ESC is searching on CSR vnf is not supported by CSR1kv XE universal and also if I do snmpwalk from ESC server it says No such object exist, that's why it is returning 0.0 value always even though I see CPU load is higher.
[root@austx-lab-dev-esc-01 ~]# snmpwalk -v2c -c public 98.6.63.71:161 1.3.6.1.4.1.2021.10.1.3.1
UCD-SNMP-MIB::laLoad.1 = No Such Object available on this agent at this OID
The correct OID which ESC should search on CSR VNF is in CISCO-PROCESS-MIB (cpmCPUTotal1minRev):
[root@austx-lab-dev-esc-01 ~]# snmpwalk -v2c -c public 98.6.63.71:161 1.3.6.1.4.1.9.9.109.1.1.1.1.7
SNMPv2-SMI::enterprises.9.9.109.1.1.1.1.7.7 = Gauge32: 0
My question: How do I tell ESC to pull CISCO-PROCESS-MIB (cpmCPUTotal1minRev) and not the UCD-SNMP-MIB::laLoad.
Is there any snmp conf on ESC server where I can add this MIB? How do I load vendor specific MIBs?
Any help appreciated!!
Neetika
ydorego
Yes as per the reported error, when applied to CSR the OID is incorrect because the OID used is the one associated to a linux MIB.
In oder for you to target a specific OID, you simply have to defined a new metric that will specifically retrieve that OID.
The following URL describe the steps to add a new metric/action. That new metric will make use of the new OID that you want to target. For example you can introduce a CSR_CPU metric.
 https://confluence-eng-sjc1.cisco.com/conf/display/ESCWIKI/Dynamic+Mapping+API
The link above has an example describing metrics for CSR OUTPUT_TOTAL_BIT_RATE.
Your new metric would be something like the following:
<metric>
        <name>CSR_CPU</name>
        <userLabel>CSR CPU</userLabel>
        <type>MONITOR_THRESHOLD</type>
        <metaData>
            <properties>
                <property>
                    <name>target_oid</name>
                    <value>.1.3.6.1.4.1.9.9.109.1.1.1.1.7</value>
                </property>
                <property>
                    <name>agent_address</name>
                    <value></value>
                </property>
                <property>
                    <name>agent_port</name>
                    <value>161</value>
                </property>
                <property>
                    <name>agent_protocol</name>
                    <value>udp</value>
                </property>
                <property>
                    <name>community</name>
                    <value>public</value>
                </property>
            </properties>
            <type>snmp_get_threshold</type>
        </metaData>
    </metric>
That new metric would have to be used instead of the default CPU one provided by ESC.
ydorego
<metric>
        <metaData>
            <properties>
                <property>
                </property>
                <property>
                    <value></value>
                </property>
                <property>
                    <value>161</value>
                </property>
                <property>
                    <value>udp</value>
                </property>
                <property>
                </property>
            </properties>
        </metaData>
    </metric>
Thanks very much! The link is pretty awesome to understand the KPIs.
