Escaping a forward slash in pattern
ysolan
Hi Team,
So far, I used the following pattern in the yang "[a-z0-9 -] *" for per example matching this string : switch01-dev001
Now, i'm looking for matching also forward slash /
i changed the pattern to "[a-z0-9-/]*"  but i doesn't work. I would like to match the following string : switch01-dev/001
Do you have an idea ?
Yannick
You could use [a-z0-9/-]*
Placing the dash last within the brackets is a 40-year old trick. That ensures it's not treated as part of any character range.
/jan
7 Replies 7
Chri_Erenti
Hi Yannick,
maybe you have to precede it with the backslash: "[a-z0-9-\/]*"
Best Regards
Christian
Hi Christian,
Thanks, I tried "[a-z0-9-\/]*"
But i have this ouput after a make :
.yang:22: error: invalid pattern: "Bad Pattern"
.yang:22:20: warning: illegal character after \
Best Regards,
Yannick
Hello Yannick,
I think solution here is to escape "-" instead of "/".
Without "-", it looks pattern is working with forward slash.
    leaf dummy {
      type string {
        pattern "[a-z0-9/]+";
  admin@ncs(config)# ytest test dummy dev/001
  admin@ncs(config-ytest-test)#
If I add "-", it fails because "-" means a range.
      type string {
        pattern "[a-z0-9-/]+";
  admin@ncs(config)# ytest test dummy switch01-dev/001
  syntax error: "switch01-dev/001" is an invalid value.
  admin@ncs(config)#
So, if I escape "-" then it works.
      type string {
        pattern "[a-z0-9\-/]+";
By the way, I prefer using "-" outside of [] such as follows.
      type string {
        pattern "[a-z0-9]+\-dev/[0-9]+";
Hope this helps.
Best regards,
Hiro
Chri_Erenti
Thank you Hiro,
you're right!
"-" is a special character inside the square brackets. Outside it is not.
It should work also in this way: "[a-z0-9]+-dev/[0-9]+" or more generic: "[a-z0-9]+-*/*"
Let me know.
Best Regards
Christian
Hello Christian,
Indeed, "-" should work without escaping outside of square brackets as "[a-z0-9]+-dev/[0-9]+".
Thank you for the correction!
Best regards,
Hiro
Hi guys,
Thanks a lot,  you have helped me to better understand the structure.
My final generic pattern is : "[a-z0-9]*-*/*";
Best regards,
Yannick
/jan
