Facing issue with ios ned upgrade
chreddy@cisco.com
Im running NSO 4.5.6 and currently having ios ned version 3.0.0.3. I deleted the old ios package in ncs-run/packages and extracted my new ned ncs-4.5.6-cisco-ios-6.0.11.tar.gz to ncs-run/packages/
I tried to do a make with clean all option. The command failed as below:
[root@localhost src]# pwd
/root/ncs-run/packages/cisco-ios/src
[root@localhost src]# make clean all
rm -rf artefacts ; rm -rf tmp-yang ; rm -f *.fxs ; rm -f schema/jsondump.pyc
rm -rf ncsc-out/* ../load-dir/*
rm -f ../private-jar/ios.jar
rm -f java/src/com/tailf/packages/ned/ios/namespaces/*.java
cd java && ant clean
/bin/bash: ant: command not found
make: *** [clean] Error 127
So, I issued, simple make. I could see some error highlighted below.
/root/nso-4.5.6/bin/ncsc --java-disable-prefix --exclude-enums --fail-on-warnings --java-package com.tailf.packages.ned.ios.namespaces --emit-java java/src/com/tailf/packages/ned/ios/namespaces/ios.java ncsc-out/modules/fxs/tailf-ned-cisco-ios.fxs
cd java && ant -q -Dpackage.name=ios -Dpackage.dir=com/tailf/packages/ned/ios all
make: *** [javac] Error 127
rm tmp-yang/tailf-ned-cisco-ios-meta.yang tmp-yang/tailf-ned-secrets.yang tmp-yang/cliparser-extensions-v11.yang tmp-yang/ietf-interfaces.yang tmp-yang/tailf-ned-cisco-ios-stats.yang tmp-yang/tailf-ned-cisco-ios-oper.yang tmp-yang/ietf-ip.yang tmp-yang/tailf-ned-cisco-ios-id.yang
I got below message in my CLI prompt window when I had done make as outlined about in root prompt.
admin@ncs#
>>> System upgrade is starting.
>>> Sessions in configure mode must exit to operational mode.
>>> No configuration changes can be performed until upgrade has completed.
>>> System upgrade has been cancelled.
I got below output saying to check if package is compiled correctly when I issued package reload:
admin@ncs> request packages reload
Error: The following Java classes look suspicious:
cisco-ios: com/tailf/packages/ned/ios/namespaces/iosId.class has modificationtim e older than the corresponding .java file
cisco-ios: com.tailf.packages.ned.ios.IOSDp is declared in package-meta-data.xml but not found
Check that the corresponding packages have been properly compiled.
If this is intended, proceed with 'force' parameter.
[error][2018-10-16 03:11:02]
Can you please help with exact steps to execute make without failure so that my latest NED reflects in the system?
vleijon
You shouldn’t need to build the NED at all, it should be built in the distribution.
But, the error you are seeing “ant: command not found” means that you have not installed ant. If you want to build java projects you should install ant.
vleijon
Hi Viktor, thanks for the clarification. I need the latest ned alone. I just replaced the the package freshly in ncs-run and updated in the cli mode. Latest ned is reflecting. Thanks a lot for quick info.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
