Failing to Fetch Host Keys
dretaylo
Hi all,
Has anyone encountered this issue before?
My configuration:
devices device loncaf-vpn-cluster-1
address loncaf-vpn-cluster-1.cisco.com port 22
device-type cli ned-id cisco-asa protocol ssh
authgroup nso-prd
state admin-state unlocked
I am attempting to ssh fetch-host-keys after committing using the NSO CLI however get the following message:
dretaylo@ncs(config-device-loncaf-vpn-cluster-1)# ssh fetch-host-keys
result failed
info Failed to connect to device loncaf-vpn-cluster-1: No supported SSH key exchange algorithms
Any help would be appreciated!
Sincerely,
Drew
This is related to the same issue. NSO tightened up the key exchange algorithms it supports, and that causes problems with some devices who use older algorithms. There are a few possibilities, one is to configure the ASA to use more modern algorithms (not sure if this is possible on ASA, I know it is possible on some devices), another is to try a newer NSO where the requirements have been relaxed slightly again.
7 Replies 7
Unfortunately the above doesn't seem to be a fix as I am seeing:
-----BEGIN RSA PRIVATE KEY-----
in my ssh_host_rsa_key file.
Could there be an issue if this seems to be coming solely from devices which are ASA OS on FPR hardware?
I don't have the issue with the rest of my fleet which are all ASAs on ASA hardware.
Hi Viktor,
You are awesome!!! Thank you so much for leading me to the answer! (and nice talking to you again)
This is way over my head however I needed to change the ssh key-exchange on the ASAs.
Do you know why I am able to use the ssh key-exchange algorithm "dh-group1-sha1" or "dh-group14-sha1" however I cannot use "dh-group14-sha256" on the ASA?
Thanks again!
Drew
What version are you running on your ASAs? It looks like support for dh-group14-sha256 was added in version 9.12, so if you are running an older version than that the option won't be available.
I just figured out another reason for this symptom:
I'm using the MacOS version of NSO to develop. To install and run NSO on ARM64-based devices, the "Rosetta" x86-emulation needs to be used. For this, I have made a copy of my terminal application for which I selected the "open with rosetta" option.
When using the wrong terminal application (native ARM64), I run into "No supported SSH key exchange algorithms" issue. So, make sure to use the correct environment on MacOS!
rensobra
Another workaround also is to allow ssh-rsa from NSO global settings. (set devices global-settings ssh-algorithms public-key ssh-rsa)
This will allow NSO to fetch "unsecured" keys...
