Fetch multiple SSH keys with RESTCONF?
scadora
I can use RESTCONF to fetch the ssh host keys for a single device like this:
curl -X POST \
http://x.x.x.x:8080/restconf/operations/devices/device=P5/ssh/fetch-host-keys \
-H 'Authorization: Basic xxxxxxxxxxxx=' \
-H 'Cache-Control: no-cache' \
-H 'Content-Type: application/yang-data+xml'
Is it possible to fetch keys from multiple devices (P1, P2, P3...) in a single POST or do I have to POST to a unique path for each device?
Shelly
I don’t know much RESTCONF without looking it up, but I think it ought to be /restconf/operations/devices/fetch-ssh-host-keys
vleijon
You can easily fetch the ssh keys for all devices at once if you call fetch-ssh-host-keys on the devices level, if that is enough for your use-case.
That would work for my use case.  However, I can't figure out how to do that in RESTCONF.
These don't work:
/restconf/operations/devices/ssh/fetch-host-keys
/restconf/operations/devices/device/ssh/fetch-host-keys
/restconf/operations/devices/device=(*)/ssh/fetch-host-keys
Help?
