Force leafrefed leaf to prepopulate in NSO web gui
u.avsec
Hi all.
Let's say I have something like this:
      leaf global-bw {
        type string;
      list cpe {
        key 'device';
        leaf device {
          type leafref {
            path "/ncs:devices/ncs:device/ncs:name";
        leaf bw {
           type leafref {
                path "../../global-bw";
          mandatory true;
Talking about native NSO web GUI; is there any way possible to force global-bw number to be displayed upfront in the bw box  when I'm filling out cpe list entry? Currently manual selection from a drop-down has to be done.
If there is a way, subquestion to this would be if a custom typedef of either leafref or string can be defaulted into prepopulating global-bw.
To me it seems that it is not possible on either account, but I would prefer to be proven wrong.
Thanks.
u.avsec
Found the answer to my case:
        leaf bw {
          type string;
          tailf:default-ref '../../global-bw';
only slight annoyance is that global-bw value is automatically populated with () like so:
 It is just cosmetics though.
u.avsec
        leaf bw {
          type string;
So that is how all default values are presented in the UI - it is the same if you use the default statement as well. It indicates that it is there implicitly but not explicitly.
