Fresh install webui login failed and access denied on load merge
logans1597
It's my first time installing nso on my mac m1 laptop. I did it via local install and ncs_cli -u admin works fine. I can do "?" and see many commands that I have access to. After searching for hours on how to solve this, it seemed like I need to get access to aaa authentication. However, when I do either one of the code below, I get syntax error: element does not exit.
show configuration aaa authentication users user
show running-config aaa authentication users user
Can someone tell me what Im doing wrong? I can't access webui using default admin/admin credentials or do load merge load.xml because I get access denied error.
You should have a default config for aaa  and nacm  .
Here the config that you should add
You have to use ncs_cli
Here the step:
I create a user admin that using a password admin . You can change it if you want.
  1. ncs_cli -u admin -C --noaaa
  2. config
  3. load merge terminal
  4. Copy paste the configuration below ( aaa & nacm)
  5. commit
aaa authentication users user admin
 uid        65534
 gid        65534
 password   admin
 ssh_keydir /var/ncs/homes/admin/.ssh
 homedir    /var/ncs/homes/admin
nacm write-default permit
nacm groups group admin
 user-name [ admin ]
nacm rule-list admin
 group [ admin ]
 rule any-access
  action permit
 cmdrule any-command
  action permit
It should solve your problem
9 Replies 9
Nabsch
Can you try to use this command since you have an issue related to AAA.
 ncs_cli -u admin -noaaa
Then execute the commands the show command aaa and give us the output that you got
I was little confused on the commands you wrote but here is the result
18:24@test-rundir:~$ ncs_cli -u admin -noaaa
User admin last logged in 2022-06-24T21:52:31.394918+00:00, to Jungs-MacBook-Pro, from 127.0.0.1 using cli-console
admin connected from 127.0.0.1 using console on Jungs-MacBook-Pro.local
admin@ncs> show command aaa
syntax error: missing display group
[error][2022-06-24 18:32:01]
admin@ncs> aaa
syntax error: expecting
  clear          - Clear parameter
  compare        - Compare running configuration to another configuration or a file
  configure      - Manipulate software configuration information
  describe       - Display transparent command  information
  exit           - Exit the management session
  file           - Perform file operations
  help           - Provide help information
  id             - Show user id information
  leaf-prompting - Automatically query for leaf values
  monitor        - Real-time debugging
  ping           - Ping a host
  ping6          - Ping an ipv6 host
  quit           - Exit the management session
  request        - Make system-level requests
  script         - Script actions
  set            - Set CLI properties
  set-path       - Set relative show path
  show           - Show information about the system
  source         - File to source
  switch         - Change CLI style
  templatize     - Find patterns in subtree.
  top            - Exit to top level and optionally run command
  traceroute     - Trace the route to a remote host
  up             - Exit one level of configuration
[error][2022-06-24 18:32:22]
admin@ncs>
Sorry for that i was talking about the command that were in your inital question .
Can you execute the command
show configuration nacm
Here is the result of the commands
19:02@test-rundir:~$ ncs_cli -u admin -noaaa
admin@ncs> config
Entering configuration mode private
[ok][2022-06-25 11:48:14]
[edit]
admin@ncs% show configuration aaa authentication users user
syntax error: element does not exist
[error][2022-06-25 11:48:17]
[edit]
admin@ncs% show configuration nacm
[error][2022-06-25 11:48:22]
[edit]
admin@ncs% exit
You don’t need to be in the config mode . Can you try the command again without the command config .
Hey Nabsch, hope you had a great weekend. Here is the output without the config mode.
9:09@test-rundir:~$ ncs_cli -u admin -noaaa
admin@ncs> show configuration aaa authentication users user
No entries found.
[ok][2022-06-27 09:53:20]
admin@ncs> show configuration nacm
No entries found.
[ok][2022-06-27 09:53:26]
admin@ncs>
Here the step:
  2. config
  5. commit
 uid        65534
 gid        65534
 password   admin
 user-name [ admin ]
 group [ admin ]
 rule any-access
  action permit
 cmdrule any-command
  action permit
Thank you Nabsch! the solution worked and I can do load merge!
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# load merge load.xml
2.90 KiB parsed in 0.02 sec (144.17 KiB/sec)
T-129
I am currently doing the NCS Orchestrator and seem to have a similar issue. Any tips or advice would be greatly appreciated.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
