07-06-2023 02:16 AM - edited 07-06-2023 02:48 AM
After deploying NSO HA Raft successfully, I'm unable to configure HA-HCC-VIP , the node id refer to the built-in HA and not to raft. As per documentation: https://developer.cisco.com/docs/nso/guides/#!high-availability/tail-f-hcc-package
admin@ncs(config-node-1)# commit dry-run
Aborted: 'hcc bgp node 1 node-id': Invalid node value
admin@ncs(config)# hcc bgp node
syntax error: incomplete path: 'hcc bgp node'
container bgp { tailf:info "VIP announcement over BGP"; description "Run a local BGP daemon and advertise VIP routes to neighbors."; list node { key node-id; leaf node-id { type leafref { path "/ncs:high-availability/ncs:ha-node/ncs:id"; } description "Unique NCS node ID"; mandatory true; }
How to reach the CLUSTER (API northbound ) with VIP ?
Solved! Go to Solution.
07-06-2023 07:16 AM - edited 07-06-2023 07:26 AM
Please run:
admin@ncs# show packages package tailf-hcc package-version
This does not seem right (from your show ha-raft above):
ha-raft status role stalled
From https://developer.cisco.com/docs/nso/guides/#!high-availability/nso-ha-raft
Additionally, NSO node can also be in the stalled state, if HA Raft is enabled but the node has not joined a cluster.
See examples.ncs/high-availability/raft-cluster for an example setup.
07-06-2023 06:01 AM
Hello, You need to upgrade the tailf-hcc package to the latest version. I.e. tailf-hcc 6.0.0 [June 26, 2023]
revision 2023-06-26 {
description
"Added support for HA Raft, changed /hcc/bgp/node leafref to
completion point and validation callback.
Released as part of tailf-hcc 6.0.0.";
container bgp {
description
list node {
key "node-id";
description
"Unique NCS HA node ID. Valid values are:
- /high-availability/ha-node when built-in HA is used or
- /ha-raft/status/member for HA Raft.";
leaf node-id {
tailf:cli-completion-actionpoint "hcc-complete-members";
tailf:validate hcc-validate-members {
tailf:dependency '.';
type string;
07-06-2023 06:08 AM
Thank you for your quick reply, indeed I can see it in yang:
list node {
key "node-id";
description
07-06-2023 06:24 AM
Your YANG snippet from your first post above shows the old YANG model:
list node {
key node-id;
leaf node-id {
type leafref {
mandatory true;
07-06-2023 07:04 AM
HCC is not recognize node-id
root@5532c14f6109:/# cat /var/opt/ncs/packages/tailf-hcc/src/yang/tailf-hcc.yang | grep node
"If set to 'true', the primary node in a cluster automatically
node. The addresses are automatically unbound when a node
to reliably connect to the primary node in the cluster.";
list node {
key "node-id";
leaf node-id {
"If set to 'true' this node uses BGP to announce VIP
root@5532c14f6109:/# ncs_cli -Cu admin
admin@ncs# show packages package oper-status
PACKAGE
PROGRAM META FILE
CODE JAVA PYTHON BAD NCS PACKAGE PACKAGE CIRCULAR DATA LOAD ERROR
NAME UP ERROR UNINITIALIZED UNINITIALIZED VERSION NAME VERSION DEPENDENCY ERROR ERROR INFO WARNINGS
cisco-asa-cli-6.13 X - - - - - - - - - - -
cisco-ios-cli-6.84 X - - - - - - - - - - -
cisco-iosxr-cli-7.36 X - - - - - - - - - - -
fortinet-fortios-cli-5.9 X - - - - - - - - - - -
tailf-hcc X - - - - - - - - - - -
admin@ncs# show ha-raft
ha-raft status connected-node [ nso02 nso03 ]
ha-raft status local-node nso01
SERIAL NUMBER EXPIRATION DATE FILE PATH
751969403D336E6C449A683459EBC626ED7DAD55 2033-06-30T09:42:50+00:00 /etc/ncs/ssl/cert/nso01.crt
5614431A97E1654D1E5C3008BACFD6CBD6D7AA95 2033-06-30T09:42:36+00:00 /etc/ncs/ssl/cert/ca.crt
ha-raft status log current-index 0
ha-raft status log applied-index 0
ha-raft status log num-entries 0
admin@ncs# config
Entering configuration mode terminal
admin@ncs(config)# hcc bgp node 1
Value for 'gobgp-bin-dir' (<string>): /bin/
Value for 'as' (<unsignedInt>): 6500
Value for 'router-id' (<IP address>): 1.1.1.1
admin@ncs(config-node-1)# exit
admin@ncs(config)#
Please run:
07-06-2023 11:10 AM
Thank you for your help, missing the ha-raft create-cluster, now I can select the node id
admin@ncs(config)# ha-raft create-cluster member [nso02 nso03 ]
admin@ncs(config)# hcc bgp node nso01 ?
Possible completions:
as BGP Autonomous System Number
disabled
enabled
gobgp-bin-dir Directory containing gobgp/gobgpd binaries
neighbor
router-id Local BGP router ID
