Hidden Commands in IOS-XE
jmaruschak
In IOS-XE, the command "ip ssh server algorithm authentication publickey keyboard password" is available via "show run all" but doesn't appear via "show run". Trying to change that in NSO by executing "devices device <device> config ios:ip ssh server algorithm authentication ?" does not work, so it appears that this command is not modeled in the NED.
Given that this is a hidden command, unavailable via "show run", is it even possible to model this in the NED? Is there some other way to configure this command across multiple devices through NSO?
NCS version 4.7
cisco-ios NED version 6.0.13
rogaglia
Sounds like an enhancement request to the IOS NED that needs to happen via Cisco TAC. Something like a NED option to "show hidden commands".
Good luck!
Roque
rogaglia
Good luck!
Roque
