How do I connect to NSO WebUI with a static IP?
BonYeol Gu
Run the nso 6.5 local-install, ncs-setup --dest ncs-run commands
The default ncs.conf is set as follows:
I set a static IP to access the webui on the same network band.
When I access the webui with a fixed IP, 400 Bad Request occurs.
Even if you set the IP to 0.0.0.0 and connect, the same 400 bad request occurs when connecting with the IP.
How can I connect with an IP other than localhost?
Thank you in advance for your reply.
Torbjørn
This should "just work". Do you get any error messages in the logs? Can you upload a (possibly censored) version of your config so that I can test?
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
cohult
Note that as of NSO 6.5, host name matching is enabled by default.
https://nso-docs.cisco.com/guides/whats-new#web-server-hostname-matching
Details:
https://nso-docs.cisco.com/guides/administration/management/system-management#exposed-interfaces
Default ncs.conf values:
/ncs-config/webui/match-host-name (boolean)[true]
/ncs-config/webui/server-name (string) [localhost
You can set match-host-name to false in your ncs.conf while developing. See link to docs above why it is recommended to enable it when deploying.
