How to create LSA dispatcher in CFS node corresponding to the package in RFS node.
chandans
I have created a simple LSA which contain one node in CFS side two nods in RFS side and created a simple package for which I am pasting the template and yang model below. I have created the NETCONF-NED in CFS side for the same package in RFS side.
I have added a device in each RFS node lets say ios1 and ios2.
<config-template xmlns="http://tail-f.com/ns/config/1.0">
  <devices xmlns="http://tail-f.com/ns/ncs">
    <device>
      <name>{/device}</name>
                 <config>
                   <interface xmlns="urn:ios">
                     <GigabitEthernet>
                       <name>{$DEVICE_ID}</name>
                       <description>{$DESCRIPTION}</description>
                     </GigabitEthernet>
                   </interface>
                 </config>
    </device>
  </devices>
</config-template>
module chandan-rfs {
  namespace "http://example.com/chandan-rfs";
  prefix rfs;
  import tailf-common {
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  description
    "Bla bla...";
  revision 2016-01-01 {
    description
      "Initial revision.";
  list chandan-rfs {
    description "This is an RFS skeleton service";
    key name;
    leaf name {
      tailf:info "Unique service id";
      tailf:cli-allow-range;
      type string;
    uses ncs:service-data;
    ncs:servicepoint chandan-rfs-servicepoint;
    // may replace this with other ways of refering to the devices.
    leaf device {
      type string;
    // replace with your own stuff here
    leaf description {
      type string;
    leaf device_id {
      type string;
Can anyone please help how to write the dispatcher in CFS side node?
alam.bilal
Here is a very basic example (repeat, basic example ) but you will get the gist of it. The following would be the CFS model and the accompanying mapping. I've used a basic XML based crude dispatch. Proper way would be to have another model which keeps the mappings (which requests get mapped to which rfs-node). Look that up (using python/java logic) to find out the rfs-node the request should go to:
module chandan-cfs {
  namespace "http://example.com/chandan-cfs";
  prefix cfs;
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  description
    "Bla bla...";
    description
  list chandan-cfs {
    description "This is an cfs skeleton service";
    key name;
    leaf name {
      type string;
    ncs:servicepoint chandan-cfs-servicepoint;
    leaf device {
      type string;
    leaf description {
      type string;
    leaf device_id {
      type string;
<config-template xmlns="http://tail-f.com/ns/config/1.0" servicepoint="chandan-cfs-servicepoint">
    <device>
      <name when="{starts-with(/device, 'SYD')}">rfs-node-syd</name>
      <name when="{starts-with(/device, 'MEL')}">rfs-node-mel</name>
      <config>
        <chandan-rfs xmlns=""http://example.com/chandan-rfs>
          <name>{/name}</name>
          <device>{/device}</device>
          <description>{/description}</description>
          <device_id>{/device_id}</device_id>
        </chandan-rfs>
      </config>
    </device>
  </devices>
</config-template>
alam.bilal
  prefix cfs;
    prefix tailf;
  import tailf-ncs {
    prefix ncs;
  description
    "Bla bla...";
    description
  list chandan-cfs {
    key name;
    leaf name {
      type string;
    leaf device {
      type string;
    leaf description {
      type string;
    leaf device_id {
      type string;
    <device>
      <config>
        </chandan-rfs>
      </config>
    </device>
  </devices>
</config-template>
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
