How to decrypt remote-password from auth group
nisheeth
I have created the an auth group and thru api query I can retrieve the auth group int he code
/restconf/data/tailf-ncs:devices/authgroups/group=<group-name> or use maapi
Now i get the encrypted remote-password how do i decrypt the remote password for use
Nisheeth
Daniel Kratz
Hi @nisheeth ,
Thanks to NSO architecture, in most of the cases, you don't need to access the user credentials.
For exceptions, you need to use the maapi api to retrieve the nso cryptographic material, and then use nso low level decrypt procedure to have access to the clear password.
https://developer.cisco.com/docs/nso/api/_ncs-maapi/#header-functions
def install_crypto_keys(sock)
Copy configured DES3 and AES keys into the memory in the library.
Keyword arguments:
  • sock – a python socket instance
https://developer.cisco.com/docs/nso/api/_ncs/#header-functions
def decrypt(ciphertext) ‑> str
When data is read over the CDB interface, the MAAPI interface or received in event notifications, the data for the builtin types tailf:des3-cbc-encrypted-string, tailf:aes-cfb-128-encrypted-string and tailf:aes-256-cfb-128-encrypted-string is encrypted. This function decrypts ciphertext and returns the clear text as a string.
Keyword arguments:
  • ciphertext – encrypted string
In the following document you can find a code example.
https://developer.cisco.com/docs/nso-guides-6.3/python-api-overview/#advanced-topics
Example 102. Setting of configuration data using MAAPI
import socket
import _ncs
from _ncs import maapi
sock_maapi = socket.socket()
maapi.connect(sock_maapi,
              ip='127.0.0.1',
              port=_ncs.NCS_PORT)
maapi.load_schemas(sock_maapi)
maapi.start_user_session(
                  sock_maapi,
                  'admin',
                  'python',
                  '127.0.0.1',
                  _ncs.PROTO_TCP)
maapi.install_crypto_keys(sock_maapi)
th = maapi.start_trans(sock_maapi, _ncs.RUNNING, _ncs.READ)
path = "/devices/authgroups/group{default}/umap{admin}/remote-password"
encrypted_password = maapi.get_elem(sock_maapi, th, path)
decrypted_password = _ncs.decrypt(str(encrypted_password))
maapi.finish_trans(sock_maapi, th)
maapi.end_user_session(sock_maapi)
sock_maapi.close()
print("Default authgroup admin password = %s" % decrypted_password)
