How to do a license migration in NSO?
snovello
Does anyone have a procedure for migrating smart licenses from one NSO server to another?
In particular when moving from a fixed server to an NSO server in docker, is the token registration persisted in cdb or should it be done on every server start? How is the token in the old server unregistered? Is there a command or can that only happen when you switch the old server off? In what order should the un-registering and registeing of the new token occur?
Thanks for any help
0 Replies 0
