How to do partial-sync-from using python maapi or maagic
nso20
Level 3
Level 3
I did partial-sync-from from NSO CLI as per NSO user guide. But I need to do partial-sync-from using python maapi or maagic, I tried the below, but no luck:
with ncs.maapi.Maapi() as m:
    with ncs.maapi.Session(m, 'admin', 'python'):
        with m.start_read_trans() as t:
            root = ncs.maagic.get_root(t)
            out = root.devices.partial_sync_from.path.[ /devices/device[name=\'cisco\']/config/ios:ip/vrf ]
yfherzog
See if this post helps you: https://community.cisco.com/t5/nso-developer-hub-discussions/call-partial-sync-from-function-in-cb-create/m-p/3895272/highlight/true#M4055
(you should not call it from cb_create(), but I think the process is correct)
nso20
Level 3
Level 3
Can anyone help here ?
yfherzog
