how to implement NSO command devices device device-name live-status xpon-stats:exec show running-config-interface if-name in Java
Hi all,
I have to implement a java service which executes the following command:
devices device deviceName live-status xpon-stats:exec show running-config-interface xgei-xx/xx/xx
This is  java code to implement the first part of the command:
  NavuContainer devContainer =ncsRoot.container("devices").list("device").elem(oltName);
  NavuContainer liveStatusContainer =devContainer.container("live-status");
  NavuContainer execContainer= liveStatusContainer.container("xpon-stats:exec");
  NavuAction actionShow = execContainer.action("show");
Unfortunately I can't find java API that can be used to add parameters to action show.
I know in Python it is possible to invoke the command by passing the input object into the device.live_status.ios_stats__exec.show() method in this way:
with ncs.maapi.Maapi() as m:
with ncs.maapi.Session(m, 'admin', 'python'):
root = ncs.maagic.get_root(m)
device = root.devices.device[device_name]
input1 = device.live_status.ios_stats__exec.show.get_input()
input1.args = [command]
output = device.live_status.ios_stats__exec.show(input1).result
print(output)
Can anybody help me to do the same in Java?
Thanks in advance for any contribution!
gmuloche
in the configuration guide you have an example on how to use an NavuAction with parameters (nso_development guide) - in the section Java API Overview / NAVU API - at the bottom of the page. The paramaters are passed using the ConfXMLParam structure.
From the page:
        NavuAction ping = if.action(interfaces.i_ping_test_);
         * Execute action.
        ConfXMLParamResult[] result = ping.call(new ConfXMLParam[] {
                new ConfXMLParamValue(new interfaces().hash(),
                                      interfaces._ttl,
                                      new ConfInt64(64))};
        //or we could execute it with XML-String
        result = ping.call("<if:ttl>64</if:ttl>");
gmuloche
From the page:
         * Execute action.
                                      interfaces._ttl,
