How to obtain specific data from staros using curl
nisheeth
I am working with NSO automation team and I am new
If I run generic query for config i get all the data I need to pull specific data using curl
My query using curl is success full and it returns tons of data
curl --location 'http://localhost:8080/restconf/data/tailf-ncs:devices/device=ORUD0407/config/tailf-ned-cisco-staros:context/' \
--header 'Accept: application/yang-data+json' \
--header 'Authorization: Basic ###############################'
"name": "up",
"bgp": "extended-asn-cap",
"bfd-protocol": {
"slow-timers": 1000
"ip": {
"igmp": [ { "profile": "default" } ],
"prefix-list": [ {"name": "up", "seq": "10", "action": "permit", "addresses": "10.193.124.144/28", "le": 32},
{"name": "up", "seq": "15", "action": "permit", "addresses": "10.193.126.0/28", "le": 32 },
{"name": "up","seq": "20","action": "permit", "addresses": "10.193.126.16/28","le": 32 },
{"name": "up", "seq": "25", "action": "permit", "addresses": "10.193.124.128/28", "le": 32 },
{"name": "up", "seq": "30", "action": "permit", "addresses": "172.30.137.80/28", "le": 32} ]
"interface": [],
"gtpp": { "group": [ { "name": "default", "gtpp": { "limit-secondary-rat-usage-conf": { "limit-secondary-rat-usage": 32 } } } ]
"gtpu-service": [],
"sx-service": [],
"user-plane-service": [ { "name": "upf_up3", "associate": {
"gtpu-service": [],
"sx-service": "sxc_up3",
"fast-path": {"service": [null]},
"control-plane-group": "cp-group-1"
"aaa": {},
"router": {},
"subscriber": {},
"route-map": [{ }]
I more interested in getting control plane group using curl and my this query fails
curl --location 'http://localhost:8080/restconf/data/tailf-ncs:devices/device=ORUD0407/config/tailf-ned-cisco-staros:context/user-service-plane' \
{ "ietf-restconf:errors": { "error": [ {
"error-type": "application",
"error-tag": "invalid-value",
"error-message": "uri keypath not found" }]
I can get same information from CLI
show running-config devices device ORUD0407 config control-plane-group
config
control-plane-group cp-group-1
peer-node-id ipv4-address 1.3.1.6
peer-node-id ipv4-address 1.3.1.7
peer-node-id ipv4-address 1.3.1.3 interface n4
peer-node-id ipv4-address 1.3.1.9 interface n4
exit
Thanks and Regards
Nisheeth
cohult
Quick tip. A simple way to figure out the correct RESTCONF path to access data in NSO CDB from a CLI show command is to pipe the show command to display restconf. Example:
show running-config devices device ORUD0407 config control-plane-group devices device ORUD0407 | display restconf
ygorelik
You have typo in the URL Try this:
curl --location 'http://localhost:8080/restconf/data/tailf-ncs:devices/device=ORUD0407/config/tailf-ned-cisco-staros:context/user-plane-service' \
snovello
Ithink its a typo, you have a URI with user-service-plane, but the data conains user-plane-service
cohult
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
