How to properly use <package-store> and <package> to pull packages from "git"?
juacosta
I created a NCS project  for my custom NSO package. I am trying to dynamically pull the dependencies of my package using the project-meta-data.xml. I have defined the following entries
<packages-store>
      <git>
        <repo>ssh://git@github.com/MyUser/net-auto-common.git</repo>
        <branch>develop</branch>
      </git>
    </packages-store>
  <package>
    <name>svc-notifications</name>
    <git/>
  </package>
<package>
    <name>svc-actions</name>
    <git/>
  </package>
When I do ncs-project update -v (included in NSO 4.4.1) , ncs-project fails indicating it cannot clone the repository. From the error, I figured out  ncs-project it is assuming my two packages svc-notifications and svc-actions are git submodules.
ncs-project error: {error,"failed to clone repository ~p\n",
                          ["git@github.com/MyUser/net-auto-common.git/svc-notifications.git"]}Trace: [{ncs_project,
        install_git_repo,
        3,
I have put both packages on its own repo and made them git submodules. Issue still exists.
However, if I declare the each package and specify each of its repos, ncs-project runs with no issues .
<package>
      <git>
        <repo>ssh://git@github.com/MyUser/svc-notifications.git</repo>
      </git
  </package>
frjansso
I believe this is what you want:
<packages-store>
      <git>
        <repo>ssh://git@github.com/MyUser</repo>
      </git>
</packages-store>
<package>
    <git>
      <branch>master</branch>
    </git>
  </package>
<package>
    <git>
      <tag>v1.0.1</tag>
    </git>
  </package>
This will get github.com/MyUser/svc-notifications and github.com/MyUser/svc-actions
Please note you can also skip the packages-store and just do
<package>
    <git>
    </git>
  </package>
frjansso
<packages-store>
      <git>
      </git>
</packages-store>
<package>
    <git>
    </git>
  </package>
<package>
    <git>
      <tag>v1.0.1</tag>
    </git>
  </package>
<package>
    <git>
    </git>
  </package>
Fredrik
Thanks a lot for the reply. I tried your suggestion and it works. To summarize, the individual packages I want to use as dependencies must be on their own repo.
Is there any chance we can get the NSO Developer's Guide updated to include a note that describes that behavior. Also the ability to pull a code base by tag. Lastly, can we document what other attributes can be specified on  the <git> </git> grouping. It will be great.
--Juan
