How to use device specific NED setting in XML template
nitinkgoud
Hello All,
I am using the following NED setting in NSO.
devices device DEVICE_NAME ned-settings api class-map-match-multi-line-format false
I would like to use this device specific NED setting in the if statement of my template file. I have tried a few options but they did not work.
<?if {/devices/device[name=/device]/ned-settings/cisco-ios-meta:cisco-ios/api/class-map-match-multi-line-format}?>
<?if {/devices/device[name=current()/device]/ned-settings/cisco-ios-meta:cisco-ios/api/class-map-match-multi-line-format}?>
Any help will be greatly appreciated.
huayyang
nitinkgoud
Thank you. This works now.
