How to use resource-manager ip_allocator in python
jfloresr
I have the following python code. I get an allocation that I can see when I do show resource-pools but I am not able to convert the "net" object into a string or ipaddress object.
        pool_name = "LOOPS"
        alloc_name = service.name
        self.log.info("Allocating Loopback IP")
        ip_allocator.net_request(service,
                                "/services/leaf-connectivity:leaf-connectivity[name='%s']" % (service.name),
                                tctx.username,
                                pool_name,
                                alloc_name,
                                32)
        net = ip_allocator.net_read(tctx.username, root, pool_name, alloc_name)
        if not net:
                self.log.info("Alloc not ready")
                return
-->     loopback_net = ipaddress.ip_network(str(net)) <--THIS IS WHERE IT BREAKS
Does anybody have an example?
gschudel
I've found that (in python) using the "ipaddress" module makes many tasks easy.
from the Resource Allocator, i've done this:
import ipaddress
#...skip
        tempip = ipaddress.IPv4Network(unicode(net), strict=True)
        vrtrpubip = tempip.network_address            # e.g. 10.87.163.146
you can find details on all the things "ipaddress" can do here:
https://docs.python.org/3/howto/ipaddress.html
here are a few that i've used... (as another example)
        insideVLN = ipaddress.ip_interface(unicode(inVlannet))
        insideVLNip = insideVLN.ip
        insideVLNnet = insideVLN.network
        insideVLNnetGW = insideVLNnet[1]
hth
gregg
gschudel
import ipaddress
#...skip
hth
gregg
Thanks for replying, I actually st got it while trying a few things.
I was using the ipaddress module but was not converting the allocated network to utf-8 while passing it and I was getting an error.
It is working node using the following:
ipaddress.ip_network(unicode(net, "utf-8")
service.leaf_loopback_ip = str(ip)
If you want to get the IP address of whichever interface is used to connect to the network without having to know its name, you can use this:
import socket
def get_ip_address():
s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
s.connect(("8.8.8.8", 80))
return s.getsockname()[0]
You do not have to have a route to 8.8.8.8 to use this. All it is doing is opening a socket, but not sending any data.
