Package reload-result with “info –ERROR—”
Fantolino
After package reload some packages results in error:
cisco@ncs> request packages reload
reload-result {
    package Itential Tools
    result false
    info --ERROR--
reload-result {
    package cisco-ios
    result false
    info --ERROR--
reload-result {
    package cisco-iosxr
    result false
    info --ERROR--
The errored package statuses result ‘UP’, though.
cisco@ncs> show packages package oper-status
        PACKAGE
                    PROGRAM                                                        META     FILE
                    CODE     JAVA           BAD NCS  PACKAGE  PACKAGE  CIRCULAR    DATA     LOAD   ERROR
NAME            UP  ERROR    UNINITIALIZED  VERSION  NAME     VERSION  DEPENDENCY  ERROR    ERROR  INFO
Itential Tools  X   -        -              -        -        -        -           -        -      -
cisco-ios       X   -        -              -        -        -        -           -        -      -
cisco-iosxr     X   -        -              -        -        -        -           -        -      -
What is the problem? How can I solve it?
gmuloche
at this stage difficult to give a good answer. For both NEDs (and I believe should be the same for Itential package) you may have some information in the Java logs (ncs-java-vm.log file). Otherwise look at devel.log as well if anything pops up there. Do you have any other Java package (the ones you are not mentioning / are not erroring)
The packages appears up do you see any issue using them?
yfherzog
Might be that you're running out of memory?
Thanx for the replay. I don’t think there memory shortage.
Jason Belk
One thing I see is that you are logged in as your local computer user into NSO "cisco@ncs", rather than a user which has admin access to the application. The default user for NSO local install is admin. You can login as admin by doing
ncs_cli -C -u admin
instead of just doing
ncs_cli -C
The -C gives you the Cisco style CLI (if you don't have it it is Junos style).
gmuloche
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
