info Device RD does not have a Network Element Driver registered
Etts Equinox
Hello Guys,
I'm trying add a device via netconf ned, and when it comes to check sync, i get an error that says " Device RD does not have a Network Element Driver registered". i have no idea what i could do to in order to get device in sync
running configuration result
devices device RD
address   192.168.67.150
port      830
ssh host-key ssh-dss
  key-data "AAAAB3NzaC1kc3MAAACBANA/ZzjfsOJ7i02sCIw9HhPBvFhiUMbAiXlWNHDOFGB52sgTyLhR\nqSbaG71ATidmyS/ropRZIpgbkSKnvT7fiZTMPaOUARjS93RbAZsu3DpSERpZZX3s/7zQIKfp\nFAvxErBNZVO0BVjhK1qHoH5wKQqLrM2CNn3099yCl6PvdatTAAAAFQDzsdrvsrNMVl6oxeKy\nO79RmM8UiQAAAIALFfIWYBSxj92BIonReTGZwJFctDkJS3ZWECAyz6kxi5BT9aruIOT/LrnF\nZin7eeXsYLS4U9+zGxUKdou6etaDdMkhvcSr9WYdbZbZa0Z5oZ9JssO8bxlJo6EM3snjoj3D\n4F37S43rFBLYcIF/jiG4Js/96mP3rnW23xsW4Kjy1wAAAIEAi8CtO98SojvJqiLlMFeFaOxz\nxRm0bg6CWyh4uNtJBDNh3Wo59kuScHFkYaLE1YDyyaVqoe357Z8wh+F2w/+HxG1yVRBv9K90\n9ACQ5zqzch5Puzlhpt6tEEQtH8vQpNIBAbmbWdRUqNHdw7wimV9oTzmBhl4rTD9XZetMe/gG\nXf4="
ssh host-key ssh-rsa
  key-data "AAAAB3NzaC1yc2EAAAADAQABAAAAgQC3Te8jg9jdMfc8i42UNmHLmwCP2vyuSK3efodSayXb\nfDuQtr3lWOQKizblfCX0w8UFL4xCpamHENPKKNn8xPSz8z6unxOT5O+tXuOXytGaoeuNT1gE\n2Y4kTpXdoERRP7YKPLWmsHNkI8cfIu7E0ju3VJIu5TaJazsvY9cwsvhb5Q=="
authgroup test
device-type netconf
state admin-state unlocked
config
  cisco-ios-xr:admin
   exit-admin-config
device_check_sync_from result
sync-result {
    device RD
    result false
You'll need to build a NETCONF NED to interface with the device in question.
-Dan
Jan Lindblad
What does   show packages package oper-status   display?
How did you get/produce the NED package? Did you build it?
Etts Equinox
no i have not produce that ned package and i used only ios and iosxr to make it work
packages package Media-Gateway
oper-status up
packages package TE
oper-status up
packages package cisco-ios
oper-status up
packages package cisco-iosxr
oper-status up
packages package dp
oper-status program-code-error
oper-status error-info [LOAD_PACKAGE[com.example.dp.dpDp]]
packages package interfaces
oper-status file-load-error
oper-status error-info "[interfaces-template.xml:1 Unknown servicepoint: interfaces]"
-Dan
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
