Instillation of NSO in Ubuntu 19.04 help
rward2801
I have followed this guide https://developer.cisco.com/docs/nso/#!getting-nso/getting-nso
but It says the folder nso-5.1 is not empty when it is. So I created folder nso-5.01 is runs and says it is completed but that folder is empty.
rw@rw-NSO:~$ sudo sh nso-5.1.0.1.linux.x86_64.installer.bin $Home/nso-5.1
ERROR ** /nso-5.1 is not empty, aborting installation
rw@rw-NSO:~$ sudo sh nso-5.1.0.1.linux.x86_64.installer.bin $Home/nso-5.1.0
INFO Using temporary directory /tmp/ncs_installer.2891 to stage NCS installation bundle
INFO Unpacked ncs-5.1.0.1 in /nso-5.1.0
INFO Found and unpacked corresponding DOCUMENTATION_PACKAGE
INFO Found and unpacked corresponding EXAMPLE_PACKAGE
INFO Generating default SSH hostkey (this may take some time)
INFO SSH hostkey generated
INFO Environment set-up generated in /nso-5.1.0/ncsrc
INFO NCS installation script finished
INFO Found and unpacked corresponding NETSIM_PACKAGE
INFO NCS installation complete
rw@rw-NSO:~$ ls
cisco_x509_verify_release.py nso-5.1.0 README.signature
Desktop nso-5.1.0.1.linux.x86_64.installer.bin tailf.cer
Documents nso-5.1.0.1.linux.x86_64.installer.bin.signature Templates
Downloads nso-5.1.0.1.linux.x86_64.signed.bin Videos
Music Pictures
nso-5.1 Public
rw@rw-NSO:~$ cd nso-5.1.0
rw@rw-NSO:~/nso-5.1.0$ ls
gschudel
I'm pretty sure the output told you exactly where it installed this... and you're not looking in the correct place (because of "sudo")...
look...
and... you are in "~/nso-5.1.0"   (note the "tilda")
Do a "pwd" here...
Pretty sure if you look in... "/nso-5.1.0"   (slash....) you will find your directory...
If all else fails there are the "basic Linux commands" to find things...
cd /
find . -name nso-5.1.0
(again note the "slash" ....)...
Seb Rupik
Hi there,
Shell variables are case sensitive. You are running the script referring to $Home, this is not the same as $HOME.
As a sanity check what is the output of:
sudo echo $Home
sudo echo $HOME
...this will also reveal whether running the sudo command is replacing the value of $HOME with that of the target user. ie, the files may be installed in /root/nso-5.1.0
cheers,
Seb.
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
