Interface operational state with NSO
RichardD2
We have a need to determine if a particular interface is down (not admin-down, but operationally) with NSO.
It seems trivial to detect admin-state like this, but oddly, oper-status isn't available.
The goal would to use this state in a service template and make logic decisions based on it.
thanks
R
show devices device mydevice live-status interfaces-state interface TenGigE0/0/0/0 admin-status admin-status up
show devices device mydevice live-status interfaces-state interface TenGigE0/0/0/0 oper-status % No entries found.
4 Accepted Solutions
u.avsec
If nothing else works, and if the NED is CLI perhaps do exec
admin@ncs(config)# devices device rtr live-status cisco-ios-xr-stats:exec any "command you want"
The output would have to be parsed though as it will be a string I think.
This two threads do it in python:
https://community.cisco.com/t5/nso-developer-hub-discussions/how-do-i-call-the-devices-device-foo-config-exec-action-from/td-p/3750061
https://community.cisco.com/t5/nso-developer-hub-discussions/execute-show-command-from-nso-action/td-p/3711082
RichardD2
Slight modification to the above, gives us:
admin@nso-lab(config)# devices device mydevice live-status exec any "show interface TenGigE 0/0/0/0" | include line
TenGigE0/0/0/0 is up, line protocol is up
We'll check out the python posts, much appreciated.
hazad
It looks like there might be a mismatch between the device output and what the NED expects. In /cisco-iosxr-cli-7.39/src/gili/if:interfaces-state_interface.gili you see that the NED expects "Line protocol is" with an uppercase L, while the output of the device is "line protocol is" with a lowercase l. You can try to correct it and recompile the NED.
hazad
Awesome! Yes, please go ahead and open a TAC case
8 Replies 8
Nabsch
Hello ,
Which NED are you using ?
can you provide NSO , Ned version ?
Can you execute this command and post the output that you get  .
RichardD2
Thanks for the reply,
Running NSO 5.6.5 with cisco-iosxr-cli-7.38 NED
Result of command above:
 admin-status up
 phys-address d4:6a:35:f4:44:00
 speed        10000000000
 statistics in-octets 35334763881
 statistics in-unicast-pkts 7046572
 statistics in-broadcast-pkts 2
 statistics in-multicast-pkts 4058647
 statistics in-discards 0
 statistics in-errors 1
 statistics in-unknown-protos 0
 statistics out-octets 35249134129
 statistics out-unicast-pkts 6023956
 statistics out-broadcast-pkts 3
 statistics out-multicast-pkts 4050900
 statistics out-discards 0
 statistics out-errors 0
 ipv4 forwarding true
 ipv4 mtu   9180
IP             NETMASK          ORIGIN
1.2.3.4  255.255.255.252  -
 ipv6 forwarding true
 ipv6 mtu   9180
u.avsec
RichardD2
hazad
RichardD2
Thank you, we will give it a go and see what happens.
RichardD2
@hazad - You nailed it, that was exactly the issue. Should I open a TAC case and provide this info, or another approach?
thanks
R
hazad
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
