Is it possible to generate an xpath to a node using the Python API?
Hubro
Given a Maagic "Node" object, I need to automatically generate an xpath to it.
I know NSO can already do this, as it generates xpaths when running "show full-configuration foo bar | display xpath". Is there any way to do this using NSO's Python API?
I know I can get the keypath to the node using the "_path" attribute, but that value can't be saved in a leaf with the "instance-identifier" type, as it has to be an xpath.
vleijon
You can use _ncs.xpath_pp_kpath for this.
vleijon
That sounds ideal, but there is one issue: It requires a HKeypathRef object, but all I get from node._path is a string. Is there some way to convert a string to a HKeypathRef object, or can I get a HKeypathRef from a Maagic node somehow?
This is one way to get it, although I do think it is not quite elegant:
def maagic_node_to_xpath(maagic_node):
    with ncs.maapi.single_read_trans('admin', 'system') as m:
        m.cd(maagic_node._path)
        return _ncs.xpath_pp_kpath(m.getcwd_kpath())
"getcwd_kpath" returns the current position in maapi, as a HKeypathRef. So, you first 'cd' to the required path, then get it's HKeypathRef using which you get the XPath.
/Ram
Is there any restconf equivalent call to get the service configs in xpath format?
