Issues with multiple templates in NSO
I'm trying out multiple templates in NSO for a python-based service. One template for the PE and one for the CPE. I've tested out the PE template alone and it's all working fine. But when I add the CPE template to the directory, I get this error message in my python log;
<ERROR> 30-Jan-2022::23:34:12.710 l3vpn ncs-dp-31675-l3vpn:main-1-th-38486: - item does not exist (1): The template file l3vpn-pe has not been loaded.
The funny thing is that I'm not even calling the second template from the script. Once I move the template out of the directory, all works fine again.
Then when I do call the second template from the script, I get an error message that the CPE template hasn't been found but the PE template succeeds. Once I add the template again and calls both templates, I get an error message that the PE-template cannot be found.
Any ideas?
-J
Well, figured out I had forgotten to remove the servicepoint from the templates which caused the problem.
