ncs-netsim device platform model?
jysoini
I try to test xml template that depends on device model.
Is there a way to set platform model for a simulated ncs-netsim device?
Jan Lindblad
How does your template depend on the device model, i.e. what sort of construct did you use in your template to decide which device model is used?
atupilojon
You can modify show_version.sh inside netsim device folder. Then, from NSO, issue a sync-from. You should now see this modification in show devices device <name> platform model output command.
