Kicker trigger but nothing happend
Gastonper
Hi I have a problem with a kicker.
When I make a modification in the monitor node, the kicker trigger and the action is invoqued  but nothing happend. Not mater what is in the action, Is like the action is invoqued but the python module not find it.
This is my kicker config:
kickers data-kicker config_voip
 monitor     /ncs:services/pon:pon/services/voip:voip/voip:onus/voip:port-fxs
 kick-node   .
 action-name config_fxs_port
YANG module:
augment "/ncs:services/pon:pon/pon:services" {
    list voip {
        list onus {
            list port-fxs {
        tailf:action config_fxs_port {
            tailf:actionpoint fxs_port;
            input {
                uses kicker:action-input-params;
            output {
Part of Python code:
class fxs_port(Action):
    @Action.action
    def cb_action(self, uinfo, name, kp, input, output, trans):
        self.log.info('action name: ', name)
        self.log.info('KICKER HAS BEEN KICKED')
class Main(ncs.application.Application):
    def setup(self):
        self.log.info('Main RUNNING')
        self.register_service('pon-voip', ServiceCallbacks)
        self.register_action('fxs_port', fxs_port)
If I do a commit debug kicker:
admin@ncs(config-port-fxs-0/1)# commit dry-run | debug kicker
 2020-04-15T15:13:17.728 kicker: config_voip at /ncs:services/pon:pon/pon:services/voip:voip[voip:code='26138349'] changed; invoking config_fxs_port
 2020-04-15T15:13:17.729 kicker: config_voip at /ncs:services/pon:pon/pon:services/voip:voip[voip:code='26138349']/voip:onus[voip:olt='CEYD-01Z'][voip:rack='1'][voip:shelf='1'][voip:slot='3'][voip:port='1'][voip:onuid='35']/voip:port-fxs[voip:lan-card='0'][voip:port='1'] changed; invoking config_fxs_port
But nothing else happend and "KICKER HAS BEEN KICKED" never get logged.
0 Replies 0
Polls
AI-powered tools for network troubleshooting are likely to be part of everyone’s workflow sooner or later. What is the single biggest challenge or concern you see with adopting these tools in your organization?
