maapi applyTrans performance issue
sm000x
Level 5
Level 5
Hi, Team:
I need help.
My project uses NSO for 10 years. There is a table (a list with single key)
grows very big during 10 years. Every time I insert or delete an entry from/to the table the maapi.applyTrans takes 2-3 minutes.
This really impacts the customers.
Is there any one has the same issue?
Any suggestions?
THX
sm000x
5 Replies 5
sm000x
Level 5
Level 5
Hi, Just add more information on my question.
(1) There is no device involved. The table is in cdb, to add/delete entry from the table does not trigger device actions. But it takes 2-3 minutes.
(2) By using "commit | details", I found the 99% time is spend on "dependency-triggered validation"
Hope this can provide more information.
THX
sm000x
What kind of validation constraints exist in your model?
Have you looked in the xpath log?
Adding items to a list is usually easier (require less validation work) than deleting items.
Hi, mljunggr:
Sorry for the delay.
What I found was the leafref always does a full table scan.
For example if a leaf dev-name leafref to devices/device/name, then whenever
the dev-name is used ncs does a full table scan on devices/device list. If the
devices/device list is huge (after 10 years' cumulation) then the performance is heavily impacted.
I have to take out the leafref in order to improve the performance.
After change leafref to string, the performance improved from 2-3 minutes to few
seconds.
I wish there is some way to disable the full table scan.
THX
sm000x
rogaglia
If you are using the leafref as a way to have CLI completion and WebUI drop-downs, you can check to use "tailf:non-strict-leafref" extension. I did not check its performance in large lists.
You use it this way:
      leaf name {
        type string;
        tailf:non-strict-leafref {
          path "/ncs:devices/ncs:device/ncs:name";
Hi, rogaglia:
Thank you for this exiting information. I will give it a try.
THX
sm000x
