NSO Datacenter Example Web UI
ron.whitt
Level 4
Level 4
I used to use the datacenter example to explain to customers how NSO worked and handled service lifecycle.  The web UI for that demo was nice and showed well.  I'm using 6.1 and I notice there's no way to get to the datacenter web UI any more.  Is there any way to get at that web UI in 6.1?  Thanks
Ruben Cocheno
@ron.whitt
You might find some around the github
Tag me to follow up.
Please mark it as Helpful and/or Solution Accepted if that is the case. Thanks for making Engineering easy again.
Connect with me for more on Linkedin https://www.linkedin.com/in/rubencocheno/
rogaglia
Hi Ron,
I am not sure I follow you but I do not think anything is missing in NSO 6.1. In particular, I have been able to compile the following dedicated UI in NSO 6.1: https://github.com/NSO-developer/tme-demo
The output includes a DataCenter demo. So, if you follow that pattern, everything should work. Attached some screenshots
Hi, Thanks for the reply, that is a good looking UI I'll give it a download and try.  Here is the UI I'm looking to access in the datacetnter demo
