Multi-Stage Service Model
Andrew Horrigan
I am trying to create a multi-stage service model where certain selections provide the user with different choices and/or different templates.  For example, assume the following YANG:
      leaf device-size {
        type enumeration {
            enum small;
            enum medium;
            enum large;
      leaf vnf-device-type {
        type enumeration {
            enum 1-arm;
            enum 2-arm;
            enum 3-arm;
Would it be possible to "dynamically" create a device template such that a user could select small / 1-arm and get one device configuration, but then select large / 2-arm and get another template? Or, do I need a seperate template for every permutation?  I am assuming that some of this can be done in Python with variables, but I wasn't sure if NSO had any built in features to handle this kind of model natively.
So, if I am understanding this correctly, the following lines dictate when a certain section of the XML is actually "applicable"?
  <config-template xmlns="http://tail-f.com/ns/config/1.0"
                   servicepoint="template-svc">
    <devices xmlns="http://tail-f.com/ns/ncs">
      <device>
        <name>{/device}</name>
        <config>
          <fooo>
          </fooo>
          <bar when="{/device-size='medium' && /vnf-device-type='1-arm'}">
          </bar>
          <baz when="{/vnf-device-type='2-arm'}">
          </baz>
        </config>
      </device>
    </devices>
  </config-template>
Let me give this a test - this seems super handy!  Thanks.
frjansso
Maybe a simple template service:
  list template-svc {
    key name;
    uses ncs:service-data;
    ncs:servicepoint "template-svc";
    leaf name {
      type string;
    leaf device {
      type leafref {
        path "/ncs:devices/ncs:device/ncs:name";
    leaf device-size {
      type enumeration {
        enum small;
        enum medium;
        enum large;
        type enumeration {
          enum 1-arm;
          enum 2-arm;
          enum 3-arm;
      <device>
        <config>
          <fooo>
          </fooo>
          </bar>
          </baz>
        </config>
      </device>
    </devices>
  </config-template>
      <device>
        <config>
          <fooo>
          </fooo>
          </bar>
          </baz>
        </config>
      </device>
    </devices>
  </config-template>
Yes, exactly like that. Between the {} you can put XPATH 1.0 expressions that are evaluated. The XML tags where the expressions evaluating to "false" are skipped.
