Multiversion LSA issues adding network device to 4.7.11 RFN failing
u.avsec
Hi.
We have a 5.8.1 CFN configured with two RFNs, one with 5.8.1 and the other with 4.7.11 (this one will have to stay on this version for a while because of... reasons). CFN has cisco-nso-nc-4.7 and cisco-nso-nc-5.8 packages added and reloaded, RFNs are configured and are pushing custom made services as part of LSA.
Here comes the interesting part. I would like to add network devices to RFNs while sitting in CFN CLI. Works for 5.8.1 RFN just fine. 4.7.11 RFN however is coughing:
prompt(config)# load merge terminal
devices device rfs-4.7.11
 config
  devices device test
   address   127.0.0.1
   authgroup default
   device-type cli ned-id cisco-ios
   device-type cli protocol ssh
0 bytes parsed in 3.69 sec (0 bytes/sec)
prompr(config)# commit dry-run
Aborted: RPC error towards rfs-4.7.11: data_missing: for /ncs:devices/ncs:device[ncs:name='test']/ncs:device-type/ncs:cli/ncs:ned-id: /devices/device[name='test']/device-type/cli/ned-id is not configured
I traced netconf and indeed I see the message going out to the RFN wanting to config the 'test' device and RFN responding with ned-id as not being there.
>>>>out 22-Jun-2022::16:18:43.421 user: uavsec thandle 13785 hostname cfs-nso device rfs-4.7.11 session-id=151167
<?xml version="1.0" encoding="UTF-8"?>
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2">
<edit-config xmlns:nc='urn:ietf:params:xml:ns:netconf:base:1.0'><target><running/></target><test-option>set</test-option><error-option>rollback-on-error</error-option><with-inactive xmlns="http://tail-f.com/ns/netconf/inactive/1.0"/><config>
<devices xmlns="http://tail-f.com/ns/ncs"><device><name>test</name><authgroup>default</authgroup><address>127.0.0.1</address><device-type><cli><protocol>ssh</protocol><ned-id>cisco-ios</ned-id></cli></device-type></device></devices></config></edit-config>
</rpc>
EOM
<rpc xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="3">
<prepare-transaction xmlns="http://tail-f.com/ns/netconf/transactions/1.0"><dry-run xmlns="http://tail-f.com/ns/netconf/ncs"><outformat>cli</outformat>
</dry-run>
</prepare-transaction>
</rpc>
>>>>out 22-Jun-2022::16:18:43.422 user: uavsec thandle 13785 hostname cfs-nso device rfs-4.7.11 session-id=151167
EOM
<<<<in 22-Jun-2022::16:18:43.427 user: uavsec thandle 13785 hostname cfs-nso device rfs-4.7.11 session-id=151167
#629
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="2"><rpc-error>
<error-type>application</error-type>
<error-tag>invalid-value</error-tag>
<error-severity>error</error-severity>
<error-path xmlns:ncs="http://tail-f.com/ns/ncs" xmlns:nc="urn:ietf:params:xml:ns:netconf:base:1.0">
    /nc:rpc/nc:edit-config/nc:config/ncs:devices/ncs:device[ncs:name='test']/ncs:device-type/ncs:cli/ncs:ned-id
  </error-path><error-message xml:lang="en">"cisco-ios" is not a valid value.</error-message><error-info><bad-element>ned-id</bad-element>
</error-info>
</rpc-error>
</rpc-reply>
<<<<in 22-Jun-2022::16:18:43.429 user: uavsec thandle 13785 hostname cfs-nso device rfs-4.7.11 session-id=151167
#581
<rpc-reply xmlns="urn:ietf:params:xml:ns:netconf:base:1.0" message-id="3"><rpc-error>
<error-tag>data-missing</error-tag>
<error-path xmlns:ncs="http://tail-f.com/ns/ncs">
  </error-path><error-message xml:lang="en">/devices/device[name='test']/device-type/cli/ned-id is not configured</error-message><error-info><bad-element>ned-id</bad-element>
</error-info>
</rpc-error>
</rpc-reply>
On the RFN I can see the cisco-ios NED
prompt(config)# devices device test address 127.0.0.1 device-type cli ned-id cisco-
Possible completions:
  cisco-asa  cisco-ios  cisco-ios-xr
Any similar experiences?
Nabsch
I manage to fix your issue by changing the payload
 config
  devices device test
   address   127.0.0.1
   authgroup default
   device-type cli ned-id ios-id:cisco-ios
Here a way to find such LSA payload. You can add the device directly in the RFS then perform a sync-from in the CFS and do a show command in order to get the payload.
In order to find the payload, i added a device directly on the RFS then i performed a sync-from then a show on this device from CFS
On the RFS
admin@ncs-rfs# show ncs-state ver
ncs-state version 4.7.11
admin@ncs-rfs# show running-config devices device TOTO | de-select config
devices device TOTO
 address   localhost
 authgroup default
 state admin-state unlocked
On the CFS
admin@ncs-cfs# show ncs-state ver
ncs-state version 5.8.1
admin@ncs-cfs# show running-config devices device rfs-4.7.11 config devices device TOTO
 config
  devices device TOTO
   address   localhost
   authgroup default
admin@ncs-cfs(config)# load merge terminal
 config
  devices device test
   address   127.0.0.1
   authgroup default
0 bytes parsed in 7.38 sec (0 bytes/sec)
admin@ncs-cfs(config)# commit dry-run
admin@ncs-cfs(config)# show configuration
 config
  devices device test
   address   127.0.0.1
   authgroup default
admin@ncs-cfs(config)# devices device rfs-4.7.11
admin@ncs-cfs(config-device-rfs-4.7.11)# config
admin@ncs-cfs(config-config)# devices device test
admin@ncs-cfs(config-device-test)# device-type cli ned-id ios-id:cisco-ios
admin@ncs-cfs(config-device-test)# top
 config
  devices device test
   address   127.0.0.1
   authgroup default
cli {
    local-node {
        data  devices {
                  device rfs-4.7.11 {
                      config {
                          devices {
             +                device test {
             +                    address 127.0.0.1;
             +                    authgroup default;
             +                    device-type {
             +                        cli {
             +                            ned-id ios-id:cisco-ios;
             +                            protocol ssh;
    lsa-node {
        name rfs-4.7.11
        data  devices {
             +    device test {
             +        device-type {
             +            cli {
             +                ned-id cisco-ios;
             +                protocol ssh;
Commit complete.
Nabsch
 config
  devices device test
   address   127.0.0.1
   authgroup default
On the RFS
devices device TOTO
 address   localhost
 authgroup default
On the CFS
 config
  devices device TOTO
   address   localhost
   authgroup default
 config
  devices device test
   address   127.0.0.1
   authgroup default
 config
  devices device test
   address   127.0.0.1
   authgroup default
 config
  devices device test
   address   127.0.0.1
   authgroup default
cli {
    local-node {
        data  devices {
                  device rfs-4.7.11 {
                      config {
                          devices {
             +                device test {
             +                    device-type {
             +                        cli {
             +                            protocol ssh;
    lsa-node {
        name rfs-4.7.11
        data  devices {
             +    device test {
             +        device-type {
             +            cli {
             +                ned-id cisco-ios;
             +                protocol ssh;
Commit complete.
Nice one, I didn't even thought of looking up existing devices that were synced to CFS. Thanks
