NCS drop config false deviate replace
Vinicius Evair
Visitor
I'm trying to build a ned using NSO 6.4, but compilation is failing due to my deviation file.
From devel.log, I have this error:
ncs progress usid=35 tid=1084 datastore=running context=cli trace-id=d5aafe3da82cf16c52206216ecfb575b output: augmented/[email protected]:270: error: the node is config, but refers to a non-config leaf 'name' in module 'openconfig-platform' defined at augmented/[email protected]:2703
which is not what I was expecting, as I'm changing the whole list to config false in my deviation file.
This is the list I'm trying to change:
grouping platform-subcomponent-ref-top {
  description
    "Top-level grouping for list of subcomponent references";
  container subcomponents {
    description
      "Enclosing container for subcomponent references";
    list subcomponent {
      key "name";
      description
        "List of subcomponent references";
      leaf name {
        type leafref {
          path "../config/name";
        description
          "Reference to the name list key";
      container config {
        description
          "Configuration data for the subcomponent";
        uses platform-subcomponent-ref-config;
      container state {
        config false;
        description
          "Operational state data for the subcomponent";
        uses platform-subcomponent-ref-state;
And this is the relevant part of my deviation file:
deviation /oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent{
  deviate replace {
    config false;
deviation /oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:name {
  deviate replace {
    type leafref {
      path "../oc-platform:state/oc-platform:name";
deviation /oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:config {
  deviate not-supported;
Looking through augmented/[email protected], I have a bunch of "NCS drop config false deviate replace":
  deviation "/ncs:compliance/ncs:template/ncs:ned-id/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent" {
    // NCS drop config false deviate replace
  deviation "/ncs:devices/ncs:template/ncs:ned-id/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent" {
  deviation "/ncs:devices/ncs:device/ncs:live-status/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent" {
    deviate replace;
  deviation "/ncs:devices/ncs:device/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent" {
  deviation "/ncs:compliance/ncs:template/ncs:ned-id/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:name" {
    deviate replace {
      type string;
  deviation "/ncs:devices/ncs:template/ncs:ned-id/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:name" {
    deviate replace {
      type string;
  deviation "/ncs:devices/ncs:device/ncs:live-status/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:name" {
    deviate replace {
      type leafref {
        path "/ncs:devices/ncs:device/ncs:live-status/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:state/oc-platform:name" {
          tailf:xpath-root 3;
  deviation "/ncs:devices/ncs:device/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:name" {
    deviate replace {
      type leafref {
          tailf:xpath-root 2;
  deviation "/ncs:compliance/ncs:template/ncs:ned-id/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:config" {
  deviation "/ncs:devices/ncs:template/ncs:ned-id/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:config" {
  deviation "/ncs:devices/ncs:device/ncs:live-status/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:config" {
  deviation "/ncs:devices/ncs:device/ncs:config/oc-platform:components/oc-platform:component/oc-platform:subcomponents/oc-platform:subcomponent/oc-platform:config" {
Why is this happening? Is this operation invalid? I didn't find any question like this in the forums. The closest one is this, but it doesn't apply to my case as I'm not trying to deviate a config to true.
If I change the original list directly to have config false the build-ned command runs without a problem.
huayyang
the yang spec doesn't allow leafref on config node pointing to oper node https://www.rfc-editor.org/rfc/rfc6020.html#section-9.9.2, thus the compiler error.
the config false deviation are dropped because config false nodes in those subtrees don't make sense.
I can only suggest you request oc to fix their models, or as you did fix the models directly(but I don't know if the list should be config true or false)
