04-09-2019 11:01 AM
When using ncsc to compile MIBs into YANG and the accompanying FXS files, when I look at the YANG files, I see comments everywhere where it says "NCS dropped explicit config true". There something I need to add when using the ncsc? It seems to be saying this even for fields that should be configurable as they are read-write. Do I need to add a bunch of annotations for the writable fields?
Solved! Go to Solution.
04-10-2019 01:03 AM
04-10-2019 01:03 AM
